Canon Support for SELPHY CP1200 | Canon U.S.A., Inc.
SELPHY CP1200
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
- macOS 15
- Linux
Initial Setup
Setting up additional computers
Finding your Network Key/Password
Re-establishing Printer Connection After A Network Change?
Need additional information or assistance?
SELECT ERROR CODE
WINDOWS
macOS X
Products | Windows 7 | Windows 8 | Windows 10 |
SELPHY CP1200 |
Products | El Capitan | Yosemite |
SELPHY CP1200 |
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Printer Type | Compact Photo Printer |
Printing Method | Dye-Sublimation |
Features | Borderless/Bordered, Brightness Correction, Canon PRINT Inkjet/SELPHY app3, Color Adjustment, Cropping, Date Print, DPOF7, ID Photo Print, Index Print, Image Optimize (Scene Detection, Brightness correction), Layout Print (Fixed Size, 1-up/2-up/4-up/8-up/2-up Fixed Size/Index,Shuffle), My Colors, PictBridge, Portrait Image Optimize, Reprinting, Smooth Skin, Wireless Printing1, 2.7" Tilt-up LCD, 16 Multi-Language UI, Optional Battery, Red-Eye Correction, Power Save, Anti-theft Wire Lock Slot |
Print Speed (up to) | Color: Postcard Size Borderless Photo5,8: 47 seconds Color: Card Size Photo5,8: 39 seconds |
Print Resolution (Up to) | Color: 300 x 300 dpi: 256 Levels Per Color |
OS Compatibility | Windows:10, Windows 8, Windows 8.1, Windows 7, Windows 7 SP1 Mac:11Mac OS® X v10.8 - 10.11.xMobile Operating Systems: iOS®, Android, Windows RT12, and Amazon Fire devices13 |
Standard Interfaces | Wireless LAN (IEEE 802.11b/g/n)1Card Slots (See Memory Card Support)PictBridge (USB & Wireless LAN)9Hi-Speed USB (Cable not included)USB Flash Memory |
Paper Sizes | Card Size (2.1" x 3.4"), Postcard (3.9" x 5.8"), L Size (3.5" x 4.7") , Square Label (2.0" x 2.0") |
Output Tray Capacity | 18 Sheets - Standard Paper Tray |
Physical Dimensions | 7.1"W x 5.4"D x 2.5"H |
Warranty | 1-Year limited warranty. 1-Year toll-free technical phone support.14 |
Direct Print Built In Card Reader Functions
Memory Card | SD Memory CardTM SDHC Memory CardTM SDXC Memory CardTM ADAPTER REQUIRED microSD Memory CardTM microSDHC Memory CardTM microSDXC Memory CardTM miniSD Memory CardTM miniSDHC Memory CardTM |
Software | (WINDOWS10/MAC11) SELPHY CP1200 Wireless Compact Printer Driver |
Canon Card Photo Printer Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. in the United States and Canon Canada Inc. in Canada with respect to the Canon brand Card Photo Printer (the “Product”) purchased with this limited warranty, when purchased and used in the United States or Canada. This limited warranty only applies to the Product packaged with this limited warranty. Canon U.S.A., Inc. will be referred to collectively herein as “Canon.”
The product, when delivered to you in new condition in its original container, is warranted against defects in materials and workmanship under normal use and service for a period of 1(one) year from the date of original purchase. Defective parts or a defective Product returned to Canon, or an Authorized Service Center, and proven to be detective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product as determined by Canon or the Authorized Service Center. Warranty replacement shall not extend the original period. This warranty does not cover any accessories, nor does it cover any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. Non-Canon brand equipment and software that may be distributed with the Product are sold “as is” and without warranty of any kind by Canon, including any implied warranty or condition regarding merchantability or fitness for a particular purpose, and all such warranties and conditions are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
- Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or Authorized Service Center. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the printer, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon) that cause damage to the Product or cause abnormally frequent service calls or service problems.
- Use of supplies or parts (other thank those distributed by Canon)
- If the Product has had its serial number or dating defaced, altered or removed.
- If the Product is used for commercial or industrial use.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCTS AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY, GUARANTY OR CONDITION, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON, OR ITS AUTHORIZED SERVICE CENTER. (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATION ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON, OR ITS AUTHORIZED SERVICE CENTER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON, OR ITS AUTHORIZED SERVICE CENTER, BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON, OR ITS AUTHORIZED SERVICE CENTER. (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
For Products Purchased in the U.S.A.
You may obtain technical support for your Product as follows:
E-mail support via our Web Site at www.usa.canon.com
Telephone assistance from a Canon U.S.A. Customer Care representative free of charge during regular business hours (currently Monday-Friday 9:00am-8:00pm EST, excluding holidays) at 1-800-OK-Canon (1-800-652-2666)
For Products Purchased in Canada
You may obtain technical support for your product as follows:
Telephone assistance from a Canon Canada customer Care representative free of charge during regular business hours (currently Monday-Friday 9:00am-8:00pm EST, excluding holidays) at 1-800-OK-Canon (1-800-652-2666)
Have your Product serial number and your date of purchase available when you make the call to expedite service. A Canon Customer Care representative will attempt to diagnose the nature of the problem and correct it over the telephone. If the problem cannot be corrected over the telephone, you will be asked to follow the applicable procedures for Mail-In Service. Note that a dated proof of purchase is required at the time of service. This requirement will be satisfied by providing a copy of your dated bill of sale.
*Technical support program specifics subject to change without notice.
MAIL-IN SERVICE
MAIL-IN SERVICE is a program under which your Product is repaired by a Canon U.S.A. or Canon Canada Authorized Service Center. You will be given the name, address and phone number of an Authorized Service Center, by contacting the Canon U.S.A. Customer Care Center at 1-800-828-4040 or Canon Canada Customer Information Centre at 1-800-OK-CANON (1-800-652-2666). It is your responsibility to properly package and send the defective product together with a copy of your dated proof of purchase, a complete explanation of the problem and a return address to the Authorized Service Center at your expense. Do not include any other items with the defective Product. The defective Product covered by this limited warranty will be repaired and returned to you without charge by the Authorized Service Center. Any product received bye the Authorized Service Center this is not covered by the limited warranty will be returned unrepaired, or, at the discretion of the Authorized Service Center, you may receive a written estimate of repair at such cost as the Authorized Service Center may establish from time to time.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
Canon Canada Inc.
6390 Dixie Road
Mississauga, Ontario L5T 1P7
Canada
(The above addresses are not to be used for the MAIL-IN SERVICE program.)
