Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 10.01.15
File Size 460.34 KB
Date 10.06.17
File Size 1.38 MB
Date 06.13.17
File Size 1.84 MB
Date 08.08.19
File Size 2.01 MB
Date 01.19.18
File Size 2.00 MB
Date 10.06.17
File Size 122.02 KB
IMAGE SENSOR 1/3 type CMOS (primary color filter)
NUMBER OF EFFECTIVE PIXELS Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION N/A
ANALOG VIDEO STANDARD N/A
ANALOG S/N RATIO N/A
SCANNING METHOD Progressive
LENS 3x Optical zoom Lens
FOCAL LENGTH 2.8 (W) - 8.4 mm (T)
F-NUMBER F1.2 (W) - F2.0 (T)
HORIZONTAL VIEWING ANGLE 101.2 ° (W) - 33.7 ° (T)
VERTICAL VIEWING ANGLE 74.7 ° (W) - 25.3 ° (T)
DAY/NIGHT SWITCH Auto/Manual
I/R CUT FILTER Removable
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 0.25 lux (F1.6, when shutter speed is 1/30 sec., when SSC is off)
0.07 lux (F1.6, when shutter speed is 1/8 sec., when SSC is off)
0.018 lux (F1.6, when shutter speed is 1/8 sec., when SSC is on)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.008 lux (F1.6, when shutter speed is 1/30 sec., when SSC is off)
0.002 lux (F1.6, when shutter speed is 1/8 sec., when SSC is off)
0.001 lux (F1.6, when shutter speed is 1/8 sec., when SSC is on)
FOCUS One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE Day Mode: 0.3m (12 in.) - infinity
Night Mode: 1.0m (3.3 ft.) - infinity
SHUTTER SPEED 1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000,1/4000, 1/8000 sec.
EXPOSURE Auto/Auto (Flickerless)/ Auto(Shutter-priority AE)/ Manual (Shutter Speed/Aperture/Gain)
WHITE BALANCE Auto/Select Light Source (Warm Fluorescent, White Fluorescent, Daylight Fluorescent, Mercury Lamp, Sodium Lamp, Halogen Lamp)/Lock (One-shot WB)/Manual
METERING MODE Center-Weighted/Average/Spot
EXPOSURE COMPENSATION 7 levels
SMART SHADE CONTROL 7 levels
AGC LIMIT N/A
IMAGE STABILIZER N/A
PAN ANGLE RANGE 350 ° (±175 ° )
TILT ANGLE RANGE 150 ° (±75 ° )
ROTATION ANGLE RANGE 350 ° (±175 ° )
MOVING SPEED Pan: 19.2 ° /sec., Tilt: 14.2 ° /sec., Rotation: 43.7 ° /sec. - When the Camera Angle Setting Tool is used
VIDEO COMPRESSION METHOD H.264, JPEG
VIDEO SIZE JPEG: 1280 x 960, 640 x 480, 320 x 240, 160 x 120
H.264: 1280 x 960, 640 x 480, 320 x 240
VIDEO QUALITY JPEG, H.264: 5 levels
FRAME RATE JPEG: 30 - 0.1 fps
H.264: 30/15/10 fps
MAXIMUM FRAME RATE 1280 x 960: 30 fps
I-FRAME INTERVAL Fixed
SIMULTANIOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users.
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4,IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X N/A
ONVIF Version ONVIF Ver. 1.02
IPv4 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (client), DHCP (client), DNS (client), ARP, ICMP, POP3, NTP, SMTP authentication, WV-HTTP (from Canon), ONVIF
IPv6 PROTOCOL TCP/IP, UDP, HTTP, FTP, SMTP (client), DNS (client), ICMPv6, POP3, NTP, SMTP authentication, WV-HTTP (from Canon), ONVIF
AUTO IP N/A
AUDIO COMPRESSION METHOD G.711 µ-law (64 kbps)
AUDIO COMMUNICATION METHOD Full-duplex (two-way) - Echo cancellation function compliant
AUDIO FILE PLAYBACK Available (audio files can be played back when an event is triggered by the intelligent function or external device input.)
PRIVACY MASK Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION N/A
PRESETS N/A
INTELLIGENT FUNCTION - VIDEO Moving Object Detection, Abandoned Object Detection, Removed Object Detection, and Camera Tampering Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
INTELLIGENT FUNCTION - VOLUME Volume Detection
EVENT TRIGGER TYPE External Device Input, Intelligent Function (Video), Intelligent Function (Volume), Timer
IMAGE UPLOAD FTP/HTTP/SMTP (e-mail) Temporary storage memory in camera: Max. 4 MB, Frame Rate: Max. 10 fps
EVENT NOTIFICATION HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION N/A
DAYLIGHT SAVING TIME N/A
CUSTOM SETTINGS N/A
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL F3.5mm (F0.14 in.) mini-jack connector (monaural) - Connect via an audio interface cable (included) Switch LINE IN/MIC IN in the setting page. LINE IN x 1 (connect to an amplifier microphone) or MIC IN x 1 (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL F3.5mm (F0.14 in.) mini-jack connector (monaural) - Connect via an audio interface cable (included) LINE OUT x 1 (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL Input x 2, Output x 2
ANALOG VIDEO OUT N/A
MEMORY CARD SD, SDHC, SDXC Memory Card Compatible. Frame Rate: Max. 1 fps
TEMPERATURE Temperature: -10 ° C - +50 ° C (+14 ° F - +122 ° F)
HUMIDITY Humidity: 5% - 85% (without condensation)
PoE PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER PA-V17 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE 24 V AC/12 V DC
WITH PoE Max. approx. 8.6 W
WITH AC ADAPTER Max. approx. 10.9 W
WITH 12VDC Max. approx. 9.0 W
WITH 24VAC Max. approx. 8.3 W
DIMENSIONS (F x H) F186 x 140mm (F7.32 x 5.51 in.)
MOUNTING POSITION Horizontal / Vertical
HEATER N/A
WEIGHT Approx. 1200g (2.65 lb.)
OUTDOOR READY No
IP RATING N/A
VANDAL RESISTANT No
IMPACT RESISTANCE N/A
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
