Canon Support for VB-H651VE | Canon U.S.A., Inc.
VB-H651VE
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Camera Management Tool User Manual
File Name
Heater Unit HU641-VB User Manual
File Name
Dome Unit DU640-S-VB Installation Guide
File Name
Mobile Camera Viewer Operation Guide
File Name
Network Camera Operation Guide
File Name
Network Camera Appendix – Specifications
File Name
File Name
File Name
File Name
Data Size and Bit Rate Estimates
SELECT ERROR CODE
IMAGE SENSOR | 1/3" CMOS (RGB) |
NUMBER OF EFFECTIVE PIXELS | Approx. 2.1 million pixels |
SCANNING METHOD | Progressive Scan |
LENS | 2.4x optical zoom |
FOCAL LENGTH | 2.55 (W) - 6.12mm (T) |
F-NUMBER | F1.2 (W) - F1.8 (T) |
DIGITAL ZOOM | 4x |
HORIZONTAL VIEWING ANGLE | 122.1° (W) - 50.1° (T) |
VERTICAL VIEWING ANGLE | 65.8° (W) - 28.2° (T) |
DAY/NIGHT MODE | Yes |
I/R CUT FILTER | Automatically removable infrared-cut filter |
MIN. SUBJECT ILLUMINATION - DAY (COLOR) | .035 lux (F1.2, shutter speed 1/30 sec.) |
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | .002 lux (F1.2, shutter speed 1/30 sec.) |
FOCUS MODES | Auto / One-Shot AF / Manual / Fixed at Infinity |
SHOOTING DISTANCE | Day Mode: 12 in. - Infinity Night Mode: 12 in. - Infinity |
SHUTTER SPEED | 1 - 1/16000 sec |
EXPOSURE MODES | Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/Manual (Shutter Speed, Aperture, Gain) |
WHITE BALANCE | Auto/Light Source/Manual Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp Manual: One-shot WB/R Gain/B Gain |
METERING MODES | Center-Weighted/Average/Spot |
EXPOSURE COMPENSATION | 9 levels |
SMART SHADE CONTROL | Auto / Manual / Disable Auto: 3 Levels Manual: 7 Levels |
HAZE COMPENSATION | Auto / Manual / Disable Auto: 3 Levels Manual: 7 Levels |
AGC LIMIT | 6 levels |
IMAGE STABILIZER | Digital (2 Levels) |
MOTION ADAPTIVE NOISE REDUCTION | Available |
CLEAR IR | N/A |
PAN ANGLE RANGE | 350° (±175°) |
TILT ANGLE RANGE | 150° (±75°) |
ROTATION ANGLE RANGE | 350° (±175°) |
IR ILLUMINATION RANGE | N/A |
MOVING SPEED | Pan: 20.1°/sec.
Tilt: 20.7°/sec. Rotation: 40.0°/sec. |
VIDEO COMPRESSION METHOD | JPEG, H.264 |
BIT RATE CONTROL | Target Bit Rate: 64-16384 kbps |
VIDEO SIZE | JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270 1280 x 720, 640 x 360, 320 x 180 1280 x 960, 640 x 480, 320 x 240 |
VIDEO QUALITY | JPEG, H.264: 10 levels |
FRAME RATE | JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps |
MAXIMUM FRAME RATE | 1280 x 960 : 30fps |
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION | Number of Specified Areas: Max. 8 windows |
I-FRAME INTERVAL | 0.5/1/1.5/2/3/4/5 sec. |
SIMULTANEOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients |
CAMERA CONTROL | Administrator, Authorized user, Guest user (level of control varies depending on user) |
ACCESS CONTROL | User authentication (user name and password), Host Access Restrictions (IPv4, IPv6) |
ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec |
IEEE 802.1X | EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP |
ONVIF Version | Profile S, Profile G |
IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
AUTO IP | Yes |
AUDIO COMPRESSION METHOD | G.711 µ-law (64 kbps) |
AUDIO COMMUNICATION METHOD | Full-duplex (two-way) - Echo cancellation function compliant RTP, Sound Transfer Protocol by Canon |
AUDIO FILE PLAYBACK | Available (audio files can be played back when an event is triggered by the intelligent function or external device input) |
PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
VIEW RESTRICTION | N/A |
PRESETS | Number of registers: Max. 20 positions (+Home Position) Number of Preset Tour Route: Max. 1 |
INTELLIGENT FUNCTION - VIDEO | Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection |
INTELLIGENT FUNCTION - AUDIO | Volume Detection, Scream Detection |
INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
INTELLIGENT FUNCTION - VOLUME | Volume Detection |
EVENT TRIGGER TYPE | External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch |
IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail) |
EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
ON-SCREEN DISPLAY | Available |
IMAGE CROPPING FUNCTION | Digital PTZ Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96 |
ENHANCED DIGITAL ZOOM | N/A |
DAYLIGHT SAVINGS TIME | Available |
CUSTOM SETTINGS | TBD |
NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
AUDIO INPUT TERMINAL | F3.5 mm (F0.14 in.) mini-jack connector (monaural) LINE IN (connect to an amplifier microphone) or MIC IN (connect to a microphone w/o amplifier) |
AUDIO OUTPUT TERMINAL | F3.5 mm (F0.14 in.) mini-jack connector (monaural) LINE OUT (connect to an amplifier speaker) |
EXTERNAL DEVICE I/O TERMINAL | Input x 2, Output x 2 |
ANALOG VIDEO OUT | N/A |
MEMORY CARD TYPE | microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card Compatible. |
MEMORY CARD RECORDED CONTENT | Log, Video (Event, Manual, ONVIF, Timer, Upload) |
MEMORY CARD RECORDED FRAME RATE | Max. 1 fps (JPEG)
Max. 30 fps (H.264) |
TEMPERATURE | When the heater unit (sold separately) is installed Operating Temperature Range: AC: -40°C - +55°C (-40°F - +131°F) Start-up Temperature Range: AC: -30°C - +55°C (-22°F - +131°F) - Sunshade cover (sold separately) necessary when under direct sun exposure |
HUMIDITY | 5% - 85% (without condensation) |
TEMPERATURE | -30°C - +60°C (-22°F - +140°F) |
HUMIDITY | 5% - 90% (without condensation) |
PoE | IEEE802.3af Class 0 (PoE) |
AC ADAPTER | AC Adapter: PA-V18 (100 - 240 V AC) (sold separately) |
EXTERNAL POWER SOURCE | 24VAC / 12VDC |
WITH PoE | Max. approx. 8.9W |
WITH AC ADAPTER | AC Adapter PA-V18: Max. approx. 10.2 W (100 V AC)
Max. approx. 10.4 W (240 V AC) |
WITH 12VDC | Max. Approx. 9.3W |
WITH PoE + | N/A |
WITH 24VAC+ | Max. Approx. 8.7W (with heater installed) Max. Approx. 21.7W (no heater installed) |
DIMENSIONS | (F x H) F180 x 135 mm (F7.09 x 5.31 in.) |
MOUNTING POSITION | Ceiling mount/Surface mount |
HEATER | Optional |
WEIGHT | 1710g (3.77 lb.) |
OUTDOOR READY | Yes |
IP RATING | IP66 rated |
VANDAL RESISTANT | Yes |
IMPACT RESISTANCE | IK10(20J) |
ADDITIONAL SUPPORT
CONTACT US
