Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 06.17.13
File Size 1.75 MB
Date 06.17.13
File Size 2.52 MB
Date 04.26.07
File Size 3.15 MB
Date 04.26.07
File Size 2.00 MB
Date 04.26.07
File Size 467.77 KB
Date 06.17.13
File Size 3.25 MB
Date 06.17.13
File Size 1.77 MB
Network Video Solution Camera
Video Signal Conforms to NTSC
Image Sensor 1/4-inch CCD (primary color filter)
Total Number of Pixels NTSC use: 680,000 (effective 310,000)
Scanning Method Progressive Scan
Minimum Illumination Day Mode: 1 lux (F2.0, color, 1/30 sec.)
Night Mode: 0.25 lux (F2.0, monochrome, 1/30 sec.)
Using the (optional) VB-RD41S-S Smoke Indoor Housing
Day Mode: 2 lux (F2.0, color, 1/30 sec.)
Night Mode: 2 lux (F2.0, monochrome, 1/30 sec.)
Imaging Modes Day mode, Night mode
Focusing Day Mode: 11.8 in. / Night mode: 23.6 in. for Auto/Manual focusing at wide/telephoto ends
Aperture Auto iris servo system
Lens Focal Length: 3.0mm to 7.2mm, f/2.0 to f/3.4
2.4x Power Zoom (shooting at infinity)
Viewing Angle Horizontal = 70.8° (W) to 29.6° (t)
Vertical = 51.6° (W) to 22.1° (t) (including distortion)
Pan Angle Range 340° (±170°)
Tilt Angle Range Upright Position = 115° (-25° to 90°)
Inverted = 115° (-90° to 25°)
Moving Speed Pan = Max. 90° / sec.
Tilt = Max. 70° / sec.
Infrared Cut Filter Power driven insertion / removal (Normal mode / Night Mode)
Night Mode Yes
White Balance TTL system: Auto / Manual preset / One-shot
Operating System Linux
Protocols TCP/IP, HTTP, DHCP, FTP, Webview (from Canon)
Video Compression Method Motion-JPEG compression (movie) JPEG (still pictures)
Video Compression Rate NTSC: 0.1fps to 30fps
Sound Compression Method G.711µ-law (64kbps) full duplex
Output Image Size 160 x 120, 320 x 240, 640 x 480
Display Image Size JPEG: 640×480 /320×240 /160×120
Camera Control Pan, tilt, zoom, brightness, shutter speed, focus speed, white balance
Connection Restrictions Access control (password), video connection, number of concurrent connections (maximum of 15)
Network Network LAN x 1 (RJ-45, 100 Base-TX / 10Base T auto negotiation)
Main Unit Interface Audio IN / OUT: 3.5monaural, mini-jack
IN: Connection to a microphone with amp and LINE output x 1
OUT: Connection to a speaker with amp x1
Video OUT: 3.5 monaural, mini-jack
Video composite signal output from network camera (for maintenance) x 1
External Device I/O: Input x 2, Output x 1
Dimensions Approx. 4.79 x 5.19 x 5.11 in. (Main unit only, excluding rubber feet and ceiling bracket)
Weight Approx. 1.73 lbs.
Operating Environment Temperature 0 - 40°C, humidity 20 - 85% RH (condensation free)
Power Capable of PoE power supply via LAN connector (in accordance with IEEE 802.3af compliant)
24VAC / 12VDC, (using the supplied connector, no polarity)
AC Adapter for 100VAC to 240VAC (PA-V17)
Power Consumption Max: Approx. 10W (PoE)
Max: Approx. 13W (When the AC Adapter is used)
Optional Software
Description 4075B002 / VK-16 v2.2 Network Video Recording Software
4075B001 / VK-64 v2.2 Network Video Recording Software
Title Canon Support | Firmware Notice: Network Camera VB-C300 Firmware Update Version 1.1 Rev.05
Advisory Type
Date 10.14.10
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
