Canon Support for Speedlite Transmitter ST-E3-RT | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 07.07.14
File Size 8.88 MB
Software Development Kit
Flash
Type Radio transmissions wireless Speedlite transmitter
Compatible Cameras Type A EOS cameras (E-TTL II/E-TTL autoflash)
Sync Speed High-Speed Sync provided (EOS-1D X and EOS 5D Mark III only)
Flash Exposure Confirmation Flash exposure confirmation lamp lights in green
* If it does not light, shooting is not performed with the standard exposure
AF Assist Beam N/A
Wireless Functions
Transmission System Radio Transmission
Transmission Range Approx. 98.4 ft. (30m)
Flash Ratio Control 1:8 - 1:1 - 8:1, power 1/2-stop increments
Flash Coverage Transmission Angle: 360&deg; all around
Receiver Operation Confirmation Green Light
Lit: Radio Transmissions Okay
Red Light
Lit: Not Connected
Blinking: Transmission Error/ Too many units (Sender units + receiver units = more than 16 units)
Orange Light
Lit: Sub-sender transmission
Blinking: Receiving remote release shooting, linked shooting signal
Receiver Unit SE Mode Cancellation The test flash button can be pressed to test if the receiver units fire or cancel the auto power off status.
General
Power Source AA/LRG Alkaline Batteries x2(Ni-MH and Lithium batteries can also be used)
Battery Life: Approx. 10 hours continuously *When using AA/LR6 alkaline batteries used (At a room temperature +23&deg;C/73&deg;F).
SE Mode Power off after 5 min. of idle operation
Dimensions 2.65 (W) x 2.42 (H) x 3.05 (D) in. / 67.4 (W) x 61.5 (H) x 77.4 (D) mm
Weight 3.9 oz. / 110g (excluding battery)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: Speedlite 600EX-RT and Speedlite Transmitter ST-E3-RT
Advisory Type
Date 12.08.15
Title Canon Support | Service Notice: Speedlite 600EX-RT: Caution When Using Color Filter Holder SCH-E1
Advisory Type
Date 11.16.14
Title Canon Support | Service Notice: Caution Concerning use of Lithium Batteries
Advisory Type
Date 12.16.14
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
