Canon Support for REALiS WUX450ST D Pro AV | Canon U.S.A., Inc.
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
WUX500, WUX450ST User's Manual
File Name
NMPJ Ver. 1.2 User's Manual
File Name
NMPJ Ver. 1.3 User's Manual
SELECT ERROR CODE
Main Unit Spec
Projector Specifications
Imaging Device
Reflective LCOS Panel, x3
Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
4500lm / 3460lm *2
Uniformity
80%
Contrast Ratio
2000:1
Digital Keystone
V: ±12°, H: ±12°
Optics
F Number, Focal Length
F2.7, 8.8mm
Zoom
Fixed
Electronic Zoom
12x Maximum
Focus
Fixed
Image Size
30 - 300" *3
Amount of Lens Shift
V: 0 - 75%, H: ±10%
Throw Ratio
0.56:1 *2
Image Adjustments
Image Modes
Standard, Presentation, Dynamic, Photo/sRGB, Video, User1, User2, User3, User4, User5, DICOM SIM *5
Color Adjustment
Color Level, Color Balance, Color Temperature, Gains of RGB, Offsets of RGB
Screen Color Correction
Normal, Greenboard, Adjust
Mounting
Upward, Downward, Table, Ceiling
Adjustable Feet
Bottom front: 2 places (Maximum elevation 6°)
Image Signals
Scanning Frequency
H: 15.734kHz - 75.000kHz, V: 24.000Hz - 60.317Hz
Analog PC Input
WUXGA / UXGA / WSXGA+ / SXGA+ / WXGA+/ FWXGA / WXGA / SXGA / XGA / SVGA / VGA
Digital PC Input
Component Video Input
1080p / 1080i / 720p / 576p / 576i / 480p / 480i
Digital Video Input
1080p / 1080i / 720p / 576p / 480p
Dot Clock
162MHz (Maximum)
HDBaseT input
Equivalent to the input signals for HDMI terminal
USB Data Transfer
JPEG still images only
Terminals
DVI-I
Digital PC / Analog PC input
HDMI
Digital PC / Digital Video input
RJ-45
Network Connection (1000BASE-T / 100BASE-TX / 10BASE-T)
Dsub15
Analog PC / Component Video input
Dsub9 (Control)
RS-232 Connection
USB Type A
USB Connection
Mini Jack
Audio input x2, Audio output x1
Mini Jack (Remote)
Wired remote control connection
Remote Control
Wireless Remote
Infrared (supplied) / Wired (optional)
Built-In Sound
Internal Amplifier
5W, Monaural
Lamp
Type
Super High Pressure Lamp
Life
3000H / 5000H
Power
260 / 200W *2
Ratings
Fan Noise
37 / 30 dB *2
Power Consumption
365 / 295W *2
Standby Power Consumption
1.8 - 0.2W *4
Power Voltage
AC100 - 240V : 50/60Hz
Operating Temperature
32°F - 104°F (0°C - 40°C), 20%RH - 85%RH
Storage Temperature
-4°F - 140°F (-20°C - 60°C)
Dimensions (W x H x D)
W: 13.26" (337mm), H: 5.35" (136mm), D: 16.33" (415mm)
Weight
13.88 lbs. (6.3kg)
Notes
*1: Calculated value for 100 type image
*2: Lamp mode is Full power / Power saver. Brightness in Power saver mode is only a calculated value and is not guaranteed as specification
*3: Indicates projectable range, although the optical performance is guaranteed only for 50 - 200 inches
*4: Varies depending on the combination of the HDBaseT and network settings
*5: The "DICOM SIM" image mode cannot be used for diagnosis
Title
Canon Support | Firmware Notice: REALiS WUX450ST Pro AV & REALiS WUX450ST D Pro AV: Firmware Version 01.030200
Title
Canon Support | Firmware Firmware Notice: REALiS WUX450ST Pro AV & REALiS WUX450ST D Pro AV
Title
Canon Support | Firmware Notice: REALiS WX450ST Pro AV & REALiS WX450ST D Pro AV: Firmware Version 01.060500
ADDITIONAL SUPPORT
CONTACT US
