Canon Support for REALiS 4K5020Z | Canon U.S.A., Inc.
REALiS 4K5020Z
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 01.20.20
File Size 15.13 MB
Date 12.12.18
File Size 605.78 KB
Projector Specifications
Imaging Device 0.74&quot;, LCOS Panel x3
Native Aspect Ratio 17:9 Approx.
Native Resolution 4096 x 2160
Brightness 5000/3000/2000 Lumens *1*2
Uniformity 80% *4*8
Contrast Ratio 3600:1 (Native)(all white: all black) *3
Digital Keystone V:±20°, H:±20°
Image Size 40&quot; - 600&quot; *4
Optics
F Number, Focal Length F2.1 -F2.4, f=22.6 - 39.79mm *4
Zoom 1.76x *4
Focus Powered *4
Throw Ratio 1.34 -2.35:1 *4
Image Adjustments
Image Modes Standard / Presentation / Dynamic / Photo/sRGB / Video / DICOM SIM / User 1 , 5
Color Adjustment Color Level, Color Balance, Color Temperature, Gain (R,G,B), Offset (R,G,B)
Screen Color Correction Normal / Greenboard / Adjust (custom)
Mounting Omnidirectional *6
Lens Shift V: ±73%, H: ±11% (powered) *4
Adjustable Feet Four Locations at bottom. Extension length = 14.6mm , maximum angle of inclination: ±8°
Image Signals
Scanning Frequency H: 18.000kHz - 135.000kHz, V: 23.979Hz - 60.000Hz
Digital PC Input 4096×2160, 3840×2160, 2560×1600, 2560×1440, 2048×1200, 2560×1080, 2048×1080, 1920×1080, WUXGA, UXGA, WSXGA+, SXGA+, WXGA+, FWXGA, WXGA, SXGA, XGA, SVGA, VGA
Digital Video Input 2160p, 1080p, 1080i, 720p, 576p, 480p
Dot Clock 594.000MHz (Maximum)
Terminals
HDMI Digital PC /Digital Video Input (x2)
Mini Jack Audio Input (x1), Audio Output (x1)
Wired Remote Control Connection
Trigger 12V DC (Maximum .35A)
Dsub9 RS-232C
USB type A USB Connection
WiFi IEEE 802.11b, IEEE 802.11g, IEEE 802.11N
RJ-45 HDBaseT | Network (1000BASE-T / 100BASE-TX / 10BASE-T)
Wireless Remote Infrared
Light Source
Type Blue laser diode, yellow phosphor
Life 20,000 hours *7
Rating
Fan Noise 37/32/29dB *2
Power Consumption 550W *2
Standby Power Consumption 1.6/0.25W *5
Power Voltage AC100 - 240V : 50/60 Hz
Operating Temperature 32°F - 113°F, 20%RH - 85%RH
Storage Temperature -4°F - 140°F
Weight 41.8 lbs.
Dimensions W:18.8&quot; x H:7.7&quot; x D:21.4&quot;
CANON LASER PROJECTOR LIMITED WARRANTY
Canon U.S.A., Inc. (“Canon U.S.A.”) and Canon Canada Inc. (“Canon Canada”) warrant to the original end-user purchaser that this Canon Laser Projector (the "Product"), when purchased and used in the United States or Canada, will be free from defects in workmanship and materials as follows: (a) for a period of five (5) years or 12,000 hours from the date of original purchase, whichever occurs first, under Normal Use and Service (as defined herein), or (b) for a period of one (1) year from the date of original purchase, under Extended Use and Service (as defined herein). Canon U.S.A. and Canon Canada are collectively referred to herein as “Canon”. "Normal Use and Service" means that use of the Product does not exceed an average of sixty (60) hours per week. Product usage in excess of “Normal Use and Service” is considered "Extended Use and Service". “Accessories” will be free from defects in workmanship and materials for a period of one (1) year from the date of original purchase. “Accessories” means any item packaged in the same box as the Product, except for consumable items, if any. The Product and Accessories are collectively referred to in this Limited Warranty as "Equipment". During the warranty period for the Product, and depending upon the service selected, Product returned to a Canon repair facility and proven to be defective upon inspection will, in Canon's sole discretion and without charge, be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts; (b) exchanged for a new Product or; (c) exchanged for a refurbished or reconditioned Product, as determined by the Canon repair facility. During the warranty period for the Accessories, Canon will, in its sole discretion and without charge, exchange defective Accessories for new, refurbished or reconditioned Accessories. This Limited Warranty does not cover consumable items as to which there is no warranty or replacement. Warranty exchange or replacement does not extend the original warranty periods of the Equipment.
ADVANCED WARRANTY EXCHANGE SERVICE PROGRAM
The Advanced Warranty Exchange Service Program (the “Program”) is a program in which a replacement Product is sent to you by Canon and you return to Canon the Product you originally purchased, which becomes the property of Canon. To use the Program, contact a Canon Customer Care Representative using the applicable Canon contact information below. The Canon Customer Care Representative will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the Canon Customer Care Representative determines that the Product is eligible for coverage under this Limited Warranty and that the problem cannot be corrected over the telephone, a reference number and an End User Activation Form will be issued to you. Submission of your signed End User Activation Form (the “Form”) will activate your request for an exchange, and the terms and conditions in the Form will govern Canon’s provision of services under the Program. The Form, including the Program terms and conditions, can be found at:
for Canon U.S.A. [www.usa.canon.com/AdvancedWarrantyExchange]
for Canon Canada [www.canon.ca/AdvancedWarrantyExchange]
MAIL-IN SERVICE
MAIL-IN SERVICE is a program under which your Product is repaired by a Canon U.S.A. or a Canon Canada authorized service center. Authorized service center information can be obtained by visiting www.usa.canon.com/support (US customers only) or by contacting the Canon U.S.A., Customer Care Center or Canon Canada Customer Care Department at 1-800-OK-CANON (1-800-652-2666). When you call, have your Product serial number and your date of purchase available to expedite service. A Canon Customer Care representative will attempt to diagnose the nature of the problem and correct it over the telephone. If the problem cannot be corrected over the telephone, you will be asked to follow the applicable procedures for MAIL-IN SERVICE. Note that a dated proof of purchase is required at the time of service. This requirement will be satisfied by providing a copy of your dated bill of sale.
You will be given the name, address and phone number of an authorized service center for the Product. It is your responsibility to properly package and send the defective Product, together with a copy of your dated proof of purchase, a complete explanation of the problem and a return address, to the authorized service center at your expense. Do not include any other items with the defective Product. The Product covered by this Limited Warranty and proven to be defective upon inspection will be repaired and returned to you without charge by the authorized service center. Any Product received by the authorized service center that is not covered by the Limited Warranty will be returned unrepaired, or at the discretion of the authorized service center, you may receive a written estimate of repair at such cost as the authorized service center may establish from time to time.
This Limited Warranty shall only apply if the Equipment is used in conjunction with compatible computers, peripheral equipment and software. Canon shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD "AS IS", WITHOUT WARRANTY OR CONDITION OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES, REPRESENTATIONS AND CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES, REPRESENTATIONS AND CONDITIONS REGARDING MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE EQUIPMENT. NO OTHER EXPRESS WARRANTY, REPRESENTATION, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE EQUIPMENT WILL BIND CANON. NO WARRANTY IS GIVEN ON ANY USED EQUIPMENT.
This Limited Warranty shall be void and of no force and effect if the Equipment is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon's instruction manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon who are acting in accordance with Canon's service bulletins, (d) use of supplies or parts (other than those distributed by Canon) which damage the Equipment or cause abnormally frequent service calls or service problems, or (e) use of the Equipment with non-compatible computers, peripheral equipment or software, including the use of the Equipment in any system configuration not recommended in any manual distributed with the Equipment. Nor does this warranty i) extend to any Equipment on which the original identification marks or serial numbers have been defaced, removed or altered, ii) cover the adjustment of customer-operated controls as explained in the instruction manual, iii) extend to any external interface equipment, iv) apply to the cabinet or cosmetic parts, knobs or routine maintenance, or v) cover uncrating, set up, installation, removal of the Equipment for repair or reinstallation of the Equipment after repair.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE EQUIPMENT, CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE EQUIPMENT OR DOWNLOADED FROM CANON'S WEB SITE), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE EQUIPMENT IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CANON WILL NOT BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT OR ANY COMPONENT THEREOF, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR WILL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE EQUIPMENT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE EQUIPMENT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON THIS WARRANTY WILL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE EQUIPMENT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
In order to obtain warranty service:
Canon U.S.A.
You may obtain technical support* for the Equipment as follows:
Canon Canada
E-mail support via our Web site at www.canon.ca/support
* Technical support program specifics subject to change without notice.
CANON U.S.A., INC
CANON CANADA INC.
Online Repair
Title Canon Support | Firmware Notice REALiS 4K5020Z Firmware Version 01.020100
Advisory Type
Date 07.22.19
Title Canon Support | Firmware Notice REALiS 4K5020Z Firmware Version 01.040300
Advisory Type
Date 01.06.20
Color Calibration Service
Canon USA is now offering a comprehensive display color calibration service. Whether you operate in the film, post-production, broadcast, corporate or educational world, our goal is the same: to help ensure image fidelity.
Benefits
Calibration Services
This service supports both standard and high dynamic range (HDR) workflows, and ensures your device meets industry standard specifications (SMPTE, DCI, and ITU).*
calibration screen
What to Expect
Our Imaging Science Foundation (ISF) certified professionals will travel to your site to ensure that any calibration is tailored specifically to your viewing environment. During a calibration session, several key image quality elements will be measured including: white point, grayscale, primary and secondary color chromaticity, luminance and gamma.
calibration gamma result screen
Customized Service
For added flexibility, our team can perform calibrations on virtually any type of display technology. Whether it be a consumer grade PC monitor or professional reference display, our service helps ensure your panel is operating to the best of its ability.
Additionally, to remove any ambiguity of your display’s performance, clients will also be provided with detailed pre and post calibration reports.
color calibration screen
Canon’s Color Calibration Service offers one-time calibrations, recurring service contracts, and customized training. For more information or to request a free consultation, please fill out the form below.
Request a quote
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
