Canon Support for PowerShot SD1300 IS | Canon U.S.A., Inc.
PowerShot SD1300 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.23 MB
Date 01.06.10
File Size 6.23 MB
Date 01.06.10
File Size 1.52 MB
Date 04.23.10
File Size 3.00 MB
Date 01.06.10
File Size 6.07 MB
Date 11.05.13
File Size 10.37 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 12.7 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
5.0 (W) - 20.0 (T) mm (35mm film equivalent: 28 - 112mm)
Digital Zoom
4x
Focusing Range
Normal: 1.2 in. (3 cm) - infinity (W), 1.6 ft. (50 cm) - infinity (T)
Macro: 1.2 in. - 1.6 ft. (3 - 50cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
2.7-inch TFT color LCD widescreen with wide viewing angle (PureColor System LCD)
LCD Pixels
Approx. 230,000 pixels
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W) - f/5.9 (T)
Shutter Speed
1-1/1500 sec.
15-1/1500 sec (Total shutter speed range)Shutter speeds differ depending on the shooting mode.Shutter speeds available in Long Shutter: 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1 (Unit: sec)
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent
(Standard output sensitivity. Recommended exposure index)
Light Metering Method
Evaluative*, Center-weighted average, Spot
Exposure Control Method
Program AE; i-Contrast; AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Facial Color is evaluated in Face AiAF
Built-in Flash
Auto, Red-eye Reduction, Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro
Flash Range
12 in. - 13 ft. (W), 1.6 - 6.6 ft. (T), (30 cm - 4.0 m (W), 50 cm - 2.0 m (T))
Recycling Time
10 sec. or less (battery voltage: 3.7V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto*, P, Portrait, Night Snapshot, Kids & Pets, Indoor, Face Self-Timer, Low Light, Beach, Underwater, Foliage, Snow, Fireworks, Long Shutter, Movie
*Automatically detects shooting scene
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Custom Color**Adjustment of contrast, sharpness and saturation available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
* Shooting start time (0-10 sec. (in one-second increments), 15/20/30 sec.) and number of shots (1-10 shots (in one-second increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Approx. 0.9 shots/sec. (Approx. 2.6 shots/sec. in Low Light)
Storage Media
SD/SDHC/SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format
Design rule for Camera File System, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural))
Number of Recording Pixels
Still Image: 4,000 x 3,000 (Large), 3,264 x 2448 (Medium 1), 2,592 x 1,944 (Medium 2), 1,600 x 1,200 (Medium 3/Date Stamp), 640 x 480 (Small), 4,000 x 2,248 (Widescreen), 1,600 x 1,200 (Low Light)Movie: 640 x 480 (30 fps), 320 x 240 (30 fps) up to 60 min. or 4GB per clip
Image data
Movie data
*Actual frame rate is 29.97
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
- Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition Effects), Rotate, Jump, Slide Show (Playback Interval, Repeat, Effect, Playlist).
- Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, Playback, Transition Effects (2 types), Histogram, Overexposure Warning, Index (4 - 130 thumbnails), Red-eye Correction, Resize, i-Contrast
- Movie: Normal playback*, slow motion**, pause, first frame, last frame, next frame, fast forward, fast rewind, resumeDisplays playback position and shooting time*Audio settings available in 5 levels.
**5 levels (including normal playback). Sound not available.
Erase Modes
Still Image: single image, all images The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased)Movie: Movies can be erased one at a time
Computer Interface
Hi-speed USB (dedicated connector (female) with unified type of digital video*)
* 2 mini-B compatible
Video Out
NTSC/PAL
Audio Out
Monaural
Other
SD Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1. Lithium-ion Rechargeable Battery Pack NB-6L
2. AC Adapter Kit ACK-DC40 (optional)
Shooting Capacity
Still Image: approx. 240 shots (LCD on)
Playback Time
Approx. 7 hrs*.
* LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.56 x 2.20 x 0.83 in. (90.5 x 55.8 x 21.2 mm)
Weight
Approx. 4.94 oz./140g (including battery and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
