Canon Support for PowerShot SD100 | Canon U.S.A., Inc.
PowerShot SD100
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.01.07
File Size 4.70 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 2.32 MB
Date 04.01.07
File Size 1.56 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 2x Optical/ 3.2x Digital/ 6.4x Combined Zoom
Image Capture Device
Type 1/2.7 inch Charge-Coupled Device (CCD)
Effective Pixels Approx. 3.2 million
Lens
Focal Length 5.4 - 10.8mm, f/2.8 - 3.9 zoom lens (35mm film equivalent: 35 - 70mm)
Digital Zoom 3.2x Digital Zoom (Maximum 6.4x digital zoom is available when combined with optical zoom)
Focusing Range Normal: AF: 18 in. - Infinity/ 47cm - Infinity, Macro AF: 4 in. - 18 in./ 10cm - 47cm (WIDE); 9 in. - 18 in./ 23cm - 47cm (TELE)
Autofocus System 9-point AiAF/ 1-point AF (Fixed to center)
Viewfinders
Optical Viewfinder Real-image zoom viewfinder
LCD Monitor 1.5 inch low temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8/ 7.1 (W), f/3.9/ 10 (T)
Shutter Speed 15 - 1/1,500 sec.
Exposure Control
Sensitivity Auto/ ISO 50/ 100/ 200/ 400 (equivalent ISO)
Light Metering Method Evaluative, Center-weighted Average or Spot Metering
Exposure Control Method Program AE
AE Lock Available
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom
Flash
Built-in Flash Operation Modes: Auto, Red-Eye Reduction On/ Off, Slow-Sync
Flash Range 1.6 - 9.8 ft./ 47cm - 3.0m (WIDE); 1.6 - 6.6 ft./ 47cm - 2.0m (TELE); 11 - 18 in./ 27 - 47cm (Macro) (When ISO is speed is set to AUTO)
Recycling Time Approx. 10 sec. or less
Shooting Specifications
Shooting Modes Auto, Program, Manual, Stitch Assist, Movie.
Photo Effects Vivid color, Neutral color, Low sharpening, Sepia, Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down.
Wireless Control Not Available
Continuous Shooting Approx. 2.2 shots/sec. (Large/ Fine Mode and LCD monitor is Off)
Image Storage
Storage Media SD Memory Card
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels Large: 2,048 x 1,536, Medium1: 1,600 x 1,200, Medium2: 1,024 x 768, Small: 640 x 480 pixels Movie: 640 x 480, 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Individual movie clips are limited to 3 minutes maximum per clip. Above figures show total movie capacity on various SD memory cards, measured under Canon&#8217;s standard test conditions, and may vary depending upon scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Magnification (2x to 10x), or Slide Show or Movie
Erasing Specifications
Erase Modes Still images: Single Image, All Images
Movie: Part of movie, All movie
Interfaces
Computer Interface USB (mini-B jack)
Video Out NTSC or PAL
Other SD memory card slot. Direct connection to Canon CP Printers and select Bubble Jet Direct Photo Printers (no computer required), using camera's USB cable.
Power Supply 1. Rechargeable Lithium-ion battery (NB-3L)
2. Compact Power Adapter (CA-PS500 & DC Coupler DR-900)
Important safety informationApprox. 180 shots (LCD monitor ON)
Approx. 480 shots (LCD monitor OFF)(At 73&deg;F/23&deg;C, flash used for every fourth shot)Approx. 150 min.
Power Source 1. Rechargeable Lithium-ion battery (NB-3L)
Shooting Capacity Approx. 180 shots (LCD monitor ON)
Playback Time Approx. 150 min.
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 3.35 x 2.20 x 0.94 in./ 85 x 56 x 23.9mm (Excluding protrusions)
Weight Approx. 5.82 oz./ 165g (Camera body only)
Computer System Requirements
Mac Requirements Computer Model: Power Macintosh, PowerBook, eMac, iMac or iBook OS: Mac OS 9.0 - 9.2, Mac OS X (v10.1/ 10.2). CPU: PowerPC. Interface: USB (Models with Apple genuine USB interface only).
PC Requirements Computer Model: IBM PC/ AT compatible. OS: Microsoft Windows 98 (including Second Edition)/ Me/ 2000/ XP.CPU: Pentium 150MHz or higher processor (Windows 98/ Me/ 2000),Pentium 300MHz or higher processor (Windows XP). Interface: USB (Windows 98/ Me/ 2000/ XP pre-install model only).
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
