Canon Support for PowerShot S95 | Canon U.S.A., Inc.
PowerShot S95
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 02.23.11
File Size 11.37 MB
Date 08.20.10
File Size 11.36 MB
Date 01.06.11
File Size 1.52 MB
Date 01.06.11
File Size 8.34 MB
Date 11.05.13
File Size 11.53 MB
Date 04.02.25
File Size 142.00 B
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
10.0 Megapixel, 1/1.7-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 10.4 Megapixels
Effective Pixels
Approx. 10.0 Megapixels
Focal Length
6.0 (W)-22.5mm (T) f/2.0-4.9 (35mm equivalent: 28-105mm)
Digital Zoom
4x
Focusing Range
Auto: 2.0 in./5cm - infinity (W), 12 in./30cm-infinity (T);
Normal: 2.0 in./5cm - infinity, 12 in /30cm. - infinity (T);
Macro: 2.0 in. - 1.6 ft./5 - 50cm (W) 12 in. - 1.6 ft./ 30 - 50cm (T) ;
Manual Focus: 2.0 in. - infinity/5cm - infinity (W), 1.6 ft. - infinity/50cm - infinity (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch TFT color with wide viewing angle
LCD Pixels
Approx. 461,000 pixels
LCD Coverage
100%
Maximum Aperture
f/2.0 (W) - f/4.9 (T)
Shutter Speed
1 - 1/1600 sec.
15-1/1600 sec. (Total shutter speed range)
Shutter speeds available in Tv and M:
15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 0.8, 0.6, 0.5, 0.4, 0.3,1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80,1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000,1/1250, 1/1600 (Units: sec.)
Sensitivity
Auto, ISO 80/100/125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200 equivalent in P Mode
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is also evaluated in Face Detect AiAF
** Metering frame is fixed to the center/linked to AF frame
Exposure Control Method
Program AE, i-Contrast, Manual; AE Lock, Program Shift, Safety Shift, Auto ISO Shift
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater), Custom
* Facial color is evaluated in Face AiAF (Face Detect WB)
Built-in Flash
Auto, Auto w/ Red-eye Reduction, Flash On, Flash On w/ Red-eye Reduction, Flash Off; FE lock, Safety FE, Slow Synchro
Flash Range
1.6-21 ft./50cm-6.5m (W), 3.0 - 9.8 ft./90cm - 3.0cm (T) (when sensitivity is set to ISO Auto)
Recycling Time
10 sec. or less (battery voltage=3.7V)
Flash Exposure Compensation
Shooting Modes
Auto, P, Av, Tv, M, C, Low Light, Special Scene (Portrait, Landscape, Kids&Pets, Smart Shutter*, Super Vivid, Poster Effect, Color Accent, Color Swap, High Dynamic Range, Nostalgic, Fish-eye Effect, Miniature Effect, Beach, Underwater, Foliage, Snow, Fireworks, Stitch Assist), Movie (Standard, Miniature Effect, Color Accent, Color Swap).
* Smile, Wink Self-timer, Face Self-timer
Photo Effects
My Colors
My Colors Off, Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom
Self Timer
Custom*
* Delay time (0 - 15 sec. (in one-second increments), 20/25/30 sec.) and number of shots
(1 - 10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
Normal: Approx. 1.9 shots/sec. (when shooting in P mode),Approx. 3.9 shots/sec. (when shooting in Low Light mode);
AF: Approx. 0.7 shots/sec. (when shooting in P mode),Approx. 1.0 shots/sec. (when shooting in Low Light mode);
LV: Approx. 0.8 shots/sec. (when shooting in P mode),Approx. 1.1 shots/sec. (when shooting in Low Light mode)
Storage Media
SD/SDHC Memory Card, SDXC Memory Card, MultiMediaCard, MMCplus Card, HC MMCplus Card
File Format
Design rule for camera file system, DPOF Version 1.1
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.3 (JPEG)
RAW (CR2 (Canon Original));
Video: MOV (Image: H.264; Audio: Linear PCM (Stereo))
Number of Recording Pixels
Still Image:
16:9: Large: 3648 x 2048, Medium 1: 2816 x 1584,Medium 2: 1920 x 1080, Small: 640 x 3603:2: Large: 3648 x 2432, Medium 1: 2816 x 1880, Medium 2: 1600 x 1064, Small: 640 x 424;4:3: Large: 3648 x 2736, Medium 1: 2816 x 2112, Medium 2:1600 x 1200, Small: 640 x 480, RAW: 3648 x 2736 (Fixed to 1824 x 1368 when in Low Light)1:1: Large: 2736 x 2736, Medium 1: 2112 x 2112,Medium 2: 1200 x 1200, Small: 480 x 4804:5: Large: 2192 x 2736, Medium 1: 1696 x 2112,Medium 2: 960 x 1200, Small: 384 x 480Video: Standard, Color Accent, Color Swap: 1280 x 720 (24 fps*1), 640 x 480 (30 fps*2), 320 x 240 (30 fps*2);
Miniature Effect: 1280 x 720 (Shooting: 6 fps/3 fps/1.5 fps; Playback: 30 fps*2), 640 x 480 (Shooting: 6 fps/3 fps/1.5 fps, Playback: 30 fps*2)
*1 Actual frame rate is 23.976 fps.
*2 Actual frame rate is 29.97 fps.
Image data
Movie data
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated fromCanon's standard shooting conditions. Figures for Movie Mode represent total capacityof the particular media.
Playback Modes File
Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Category, Transition Effects, Histogram, Index (4-130 thumbnails), Over Exposure Warning, Slide Show, Red-eye Correction, Trimming, Resize, Image Inspection Tool, i-Contrast;
Video: Normal Playback, Special Playback, Editing, Auto Rotate, Resume
Erase Modes
Still Image: single image, all images
Movie: part of movie, all of movie
Computer Interface
USB 2.0 Hi-Speed (mini-B jack)
Video Out
NTSC/PAL
Audio Out
Stereo
Other
Memory card slot; direct connection to Canon and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
1. Rechargeable Battery Pack NB-6L
2. Compact Power Adapter CA-DC10 (optional)Still Image: approx. 200 shots*Approx. 5 hours
Power Source
Shooting Capacity
Playback Time
Approx. 5 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.93 x 2.30 x 1.16 in. (99.8 x 58.4 x 29.5mm)
CIPA compliant
Weight
Approx. 6.00 oz. / 170g (camera body only)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
