Canon Support for PowerShot S300 | Canon U.S.A., Inc.
PowerShot S300
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.01.02
File Size 13.35 MB
Date 04.01.07
File Size 2.37 MB
Date 04.01.07
File Size 3.59 MB
Date 04.01.07
File Size 3.84 MB
Date 04.01.07
File Size 2.71 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Image Capture Device
Type 1/2.7 inch Charge-Coupled Device (CCD)
Total Pixels Approx. 2.11 million-pixel
Effective Pixels Approx. 2.02 million
Lens
Focal Length 5.4 (Wide-angle) - 16.2 (Telephoto) mm(35 mm film equivalent: 35 - 105 mm)
Focusing Range Standard: 76 cm - infinity (2.5 ft. - infinity)Macro: 16 - 76 cm (6.3 in - 2.5 f) (Wide-angle) / 26 - 76 cm (10.2 in - 2.5 ft.) (Telephoto)
Autofocus System TTL 3-point AiAF
Viewfinders
Optical Viewfinder 5.4mm (Wide angle) - 16.2mm (Telephoto)
LCD Monitor 1.5 inch low-temperature polycrystalline silicon TFT LCD
LCD Pixels 117,600 (490 x 240)
LCD Coverage 80%
Aperture and Shutter
Maximum Aperture Maximum: f/2.7 to f/8 (Wide-angle)Minimum : f/4.7 to f/14 (Telephoto)
Shutter Speed 1 - 1/1500 sec.(1-sec. for Slow-Synchro mode or manual mode with flash set to Off)(Noise reduction processing on speeds slower than 1/6 sec.)
Exposure Control
Sensitivity Equivalent to ISO 100 (automatically raised to ISO 150 in low light)
Light Metering Method Evaluative metering (linked to focusing point)
Exposure Control Method Program AE
Exposure Compensation +/-2EV (1/3 stops)
White Balance
White Balance Control TTL auto white balance, pre-set white balance (available settings: daylight, cloudy, tungsten, fluorescent), Black & White
Flash
Built-in Flash Built-in (Auto, On, Off, Red-Eye Reduction, Slow-Synchro)
Flash Range Normal: Wide angle - 76 cm-3.5m (2.5 in.-11.5 ft.), Telephoto - 76 cm-2m (2.5 in.-6.6 ft.)
Macro Mode: Wide angle - 26-76cm (10.2 in-2.5 ft.), Telephoto - 26-76cm (10.2 in.- 2.5 ft.)
Recycling Time Approx. 10 sec.
Shooting Specifications
Shooting Modes Auto/Manual/Stitch assist/Movie
Continuous Shooting Approx. 2.5 images/sec. (at large/fine mode with the LCD monitor off)
Image Storage
Storage Media CompactFlash (CF) Card Type I
File Format Design rule for Camera File system (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1; EXIF Print Compliant (EXIF 2.2)
Image Recording Format Images/Thumbnails: JPEG
Number of Recordable Images
Image data
Interfaces
Computer Interface Universal Serial Bus (USB)
Video Out Video : NTSC or PAL selectable Audio : monaural Cable type : L-type plug (3.5mm dia)
Power Supply 1. Battery Pack NB-1L rechargeable Lithium-ion battery (one)
2. Compact Power Adapter CA-PS500 (with DC Coupler DR-500)
3. AC Power Cord
Important safety information
Power Source 1. Battery Pack NB-1L rechargeable Lithium-ion battery (one)
3. AC Power Cord
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10 - 90 %
Dimensions (W x H x D) 3.7 x 2.5 x 1.2 in. (94.8 x 62.5 x 29.9mm ) (excluding lens protrusion)
Weight Approx. 8.5 oz. (240 g) (excluding batteries and CF card)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook
OS: Mac OS 8.6 through 9.1, Quicktime 3.0 or higher (QuickTime 4.1 is in the CD-ROM "DIGITAL CAMERA Solution Disk" included with the PowerShot S110 standard kit) (Please see our Mac OS X Compatibility Statement.)
CPU: Power PC
Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3/G4, iMac, iBook)
RAM: 20MB or more of application memory
PC Requirements Hardware: IBM PC/AT compatible OS: Windows 98 (including the Second Edition), Windows 2000, Windows ME (Please see our Windows XP Compatibility Statement.)
CPU: Pentium 133 MHz or better
Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems
RAM: 32MB or more (Windows 98), 64MB or more (Windows 2000/Windows ME)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
