Canon Support for PowerShot S20 | Canon U.S.A., Inc.
PowerShot S20
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.01.07
File Size 1.84 MB
Date 04.01.07
File Size 3.59 MB
Date 04.01.07
File Size 2.21 MB
Date 04.01.07
File Size 3.84 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Image Capture Device
Type 1/1.8 inch Charge-Coupled Device (CCD)
Total Pixels Approx. 3.34 million
Effective Pixels Approx. 3.24 million
Lens
Digital Zoom 6.5mm (Wide-angle)-13mm (Telephoto) (35 mm film equivalent: 32 - 64mm)
Focusing Range Standard:66cm (2.2ft) - infinity; Macro: 12cm (0.4 ft) - 66cm (2.2 ft)
Autofocus System TTL AF
Viewfinders
Optical Viewfinder Real-image optical viewfinder Magnification: 0.35 (Wide-angle) - 0.70 (Telephoto) Coverage: (V) 80% (H) 80% (when object is 2m away)
LCD Monitor 1.8 inch low-temperature polycrystalline silicon TFT LCD
LCD Pixels 113,578 dots (521 x 218)
LCD Coverage 88.7%
Aperture and Shutter
Maximum Aperture Maximum: F2.9-F8.0 (Wide-angle) Minimum: F4.0-F8.0 (Telephoto)
Shutter Speed 2-1/1,000 sec. (2 sec. for Slow Shutter or Night Scene mode)
Exposure Control
Sensitivity Equivalent to ISO 100-400 (ISO 400 for gain up setting)
Light Metering Method Center-weighted metering/spot metering
Exposure Control Method Program AE
Exposure Compensation +/- 2EV in 1/3-stop increments
White Balance
White Balance Control TTL
Flash
Flash Range 0.17 (0.6 ft) - 3.3m (10.8 ft) (wide-angle) 0.17 (0.6 ft) - 2.3m (7.5 ft) (telephoto) (in total darkness)
Recycling Time Approx. 10 sec. or shorter (battery voltage = 6.0V)
Shooting Specifications
Shooting Modes Auto, manual, flash, self-timer, macro, continuous, (1.2 fps), Stitch Assist, Image (5 menu)
Continuous Shooting 1.2 images/sec. (large/Fine in using optical finder)
Image Storage
Storage Media CompactFlash card (type I and II)
File Format Design rule for Camera File System/CIFF (playback only)
Print Order Format DPOF
JPEG Compression Mode Normal, Fine, SuperFine
Number of Recording Pixels Large: 2,048(H) x 1,536(V)Middle:1,024(H) x 768(V)Small: 640(H) x 480(V)
Number of Recordable Images
Image data
Playback Specifications
Playback Modes File Playback Modes Single image, multiple images (9 thumbnails), slideshow
Erasing Specifications
Erase Modes Single image, all images
Interfaces
Computer Interface Serial (RS 232C)/USB
Video Out NTSC
Other CF Card Slot (Type I and Type II)
Power Supply 1. 2CR Lithium-manganese Battery (Non-rechargeable)
2. NB-5H Nickel-Metal Hybrid Battery (Rechargeable)
3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter)
Power Source 1. 2CR Lithium-manganese Battery (Non-rechargeable)
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10% - 90%
Dimensions (W x H x D) 4.1 x 2.7 x 1.3 in / 105.4 x 69.4 x 33.8mm
Weight 4.1 x 2.7 x 1.3 in / 105.4 x 69.4 x 33.8mm
Computer System Requirements
Mac Requirements Hardware Power Macintosh, PowerBook, iMac or iBook OS Mac OS 7.5, Quicktime 2.1 (Please see our Mac OS X Compatibility Statement.) CPU PowerPC RAM 20 MB or more of application memory Interface USB (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook)- Limited to genuine Apple Computer brand models with built-in USB interface - iMac computers running Mac OS 8.1 require installation of the "iMac Update 1.0" and "iMac Firmware Update 1.0" RS 422 (Printer or modem port for PowerShot S10/S20 models only) Free Hard Disk Space Canon Utilities Image Browser: 20 MB or more Canon Utilities PhotoStitch: 30 MB or more Canon Digital Camera Plug-in Module: 15 MB or more Adobe PhotoDeluxe: 70 MB or more Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, Thousands of colors or more
PC Requirements Hardware IBM PC/AT compatible OS Windows 95/98 (including the Second Edition) Windows NT 4.0 (Service Pack 3 or higher required) Windows 2000Windows ME(Please see our Windows XP Compatibility Statement.) CPU Pentium 133 MHz or better RAM 32 MB or more (Windows 95/98) 64 MB or more (Windows NT/2000/ME) Interface USB (Limited to pre-installed Windows 98, Windows 2000 or Windows ME Systems as well as Windows ME Systems upgraded from Windows 98) RS-232C (Serial/COM port for PowerShot S10/S20 only) Free Hard Disk Space Canon Utilities ZoomBrowser EX: 120 MB or more (including the PhotoRecord printing utility) Canon Utilities PhotoStitch: 40 MB or more Canon Digital Camera USB TWAIN Driver: 15 MB or more Canon Digital Camera RS-232C TWAIN Driver: 15 MB or more Adobe PhotoDeluxe Home Edition: 140 MB or more (works with the Windows 95/98/NT 4.0 operating systems) Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, High Color (16 bit) or more
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
