Canon Support for PowerShot S10 | Canon U.S.A., Inc.
PowerShot S10
Language
Download Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 04.01.07
File Size 1.84 MB
Date 04.01.07
File Size 3.59 MB
Date 04.01.07
File Size 3.84 MB
Date 04.01.07
File Size 2.21 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at https://www.usa.canon.com/support/sdk. To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
Image Capture Device
Type 1/1.8 inch Charge-Coupled Device(CCD)
Total Pixels Approx. 2.11 million
Effective Pixels Approx. 2.02 million
Lens
Focal Length 6.3mm(Wide-angle) to 12.6mm(Telephoto)(35mm film equivalent: 35 - 70mm)
Focusing Range Standard:46cm (1.5 ft) to infinity
Macro: 12cm (4.7 in.) - 46cm (1.5 ft)
Viewfinders
Optical Viewfinder Real-image optical viewfinder. Magnification: 0.35 (Wide-angle) - 0.70 (Telephoto). Coverage: (V) 80% (H) 80% (when object is 2m away).
LCD Monitor 1.8 inch low-temperature polycrystalline silicon TFT LCD
LCD Pixels 113,578 dots (521 x 218)
LCD Coverage 88.7%
Aperture and Shutter
Maximum Aperture Maximum: F/2.8-F/8.0 (Wide-angle) Minimum: F/4.0-F/8.0 (Telephoto)
Shutter Speed 2-1/1,000 sec. (2 sec. for Slow Shutter or Night Scene mode)
Exposure Control
Sensitivity Equivalent to ISO 100-400 (ISO 400 for gain up setting)
Light Metering Method Center-weighted metering/spot metering
Exposure Control Method Program AE
Exposure Compensation +/- 2EV in 1/3-stop increments
White Balance
White Balance Control TTL
Flash
Flash Range 0.17 (0.6 ft) - 3.3m (10.8 ft) (wide-angle), 0.17 (0.6 ft) - 2.3m (7.5 ft) (telephoto)in total darkness
Recycling Time Approx. 10 sec. or shorter (battery voltage = 6.0V)
Shooting Specifications
Shooting Modes Auto, manual, flash, self-timer, macro, continuous, (1.7 fps), Stitch Assist, Image (5 menu)
Continuous Shooting 1.7 images/sec. (in Large/Fine mode using optical finder)
Image Storage
Storage Media CompactFlash card (Type I and II)
File Format Design rule for Camera File System
Print Order Format DPOF
Image Recording Format JPEG or CCD-RAW
JPEG Compression Mode Normal, Fine, Super Fine
Number of Recording Pixels Large: 1,600 (H) x 1,200 (V)Middle: 1280 (H) x 960 (V)Small: 800 (H) x 600 (V)
Number of Recordable Images
Image data  Storage capacity varies depending on the scene or subjects. This data is estimated from Canon's standard shooting conditions. These numbers are the values in the Auto or Program modes. In the Stitch Assist mode there is a possibility that the shooting capacity will be slightly lower than in the full Auto or Program Mode.
Playback Specifications
Playback Modes File Single image, multiple images (9 thumbnails)
Erasing Specifications
Erase Modes Single image, all images
Interfaces
Computer Interface Serial (RS 232C)/USB
Video Out NTSC
Other CF Card Slot (Type I and Type II)
Power Supply 1. 2CR5 Lithium-manganese Battery (Non-rechargeable)
2. NB-5H Nickel-Metal Hydride Battery (Rechargeable)
3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter)
Power Source 1. 2CR5 Lithium-manganese Battery (Non-rechargeable)
Physical Specifications
Operating Temperature 32°F - 104°F (0°C - 40°C)
Operating Humidity 10% - 90%
Dimensions (W x H x D) 4.1 x 2.7 x 1.3 in / 105.4 x 69.4 x 33.8 mm
Weight Approx. 270g (9.5 oz) excluding battery and CompactFlash card
Computer System Requirements
Mac Requirements Hardware Power Macintosh, PowerBook, iMac or iBook OS Mac OS 7.5, Quicktime 2.1 (Please see our Mac OS X Compatibility Statement.) CPU PowerPC RAM 20 MB or more of application memory Interface USB (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook)- Limited to genuine Apple Computer brand models with built-in USB interface - iMac computers running Mac OS 8.1 require installation of the "iMac Update 1.0" and "iMac Firmware Update 1.0" RS 422 (Printer or modem port for PowerShot S10/S20 models only) Free Hard Disk Space Canon Utilities Image Browser: 20 MB or more Canon Utilities PhotoStitch: 30 MB or more Canon Digital Camera Plug-in Module: 15 MB or more Adobe PhotoDeluxe: 70 MB or more Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, Thousands of colors or more
PC Requirements Hardware IBM PC/AT compatible OS Windows 95/98 (including the Second Edition) Windows NT 4.0 (Service Pack 3 or higher required) Windows 2000Windows ME(Please see our Windows XP Compatibility Statement.) CPU Pentium 133 MHz or better RAM 32 MB or more (Windows 95/98) 64 MB or more (Windows NT/2000/ME) Interface USB (Limited to pre-installed Windows 98, Windows 2000 or Windows ME Systems as well as Windows ME Systems upgraded from Windows 98) RS-232C (Serial/COM port for PowerShot S10/S20 only) Free Hard Disk Space Canon Utilities ZoomBrowser EX: 120 MB or more (including the PhotoRecord printing utility) Canon Utilities PhotoStitch: 40 MB or more Canon Digital Camera USB TWAIN Driver: 15 MB or more Canon Digital Camera RS-232C TWAIN Driver: 15 MB or more Adobe PhotoDeluxe Home Edition: 140 MB or more (works with the Windows 95/98/NT 4.0 operating systems) Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, High Color (16 bit) or more
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
