Canon Support for PowerShot G7 X Mark II | Canon U.S.A., Inc.
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
- Linux
0 of 0
Results will appear after selecting an Operating System and Version above
File Name
Picture Style Editor Instruction Manual
RECOMMENDED
File Name
PowerShot G7X MarkII Camera User Guide
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | 20.1 Megapixel*, 1.0-inch CMOS (sensor aspect ratio: 3:2) * Image processing may cause a decrease in the number of pixels. |
Total Pixels | Approx. 20.9 Megapixels |
Effective Pixels | Approx. 20.1 Megapixels |
Focal Length | 8.8 (W) - 36.8 (T) mm (35mm film equivalent: 24-100mm) |
Optical Zoom | 4.2x |
Digital Zoom | 4x |
Focusing Range | Normal/Auto: 2.0 in. (5 cm) - infinity (W), 1.3 ft. (40 cm) - infinity (T) Macro/Underwater Macro: 2.0 in. - 1.6 ft. (5-50 cm) (W) Quick: 5.0-65.6 ft. (1.5-20m) (W), 5.0-65.6 ft. (1.5-20m) (T) |
Autofocus System | TTL Autofocus, Manual Focus |
Optical Viewfinder | N/A |
LCD Monitor | 3.0-inch tilt-type TFT color liquid crystal, with biaxial tilt for low and high angle shooting |
LCD Pixels | Approx. 1.04 million dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/1.8 (W), f/2.8 (T) |
Shutter Speed | 1-1/2000 sec. (in Auto mode) 15 -1/2000 sec. (in all shooting modes) BULB (in M mode only) 1/8 minimum in Manual Movie Mode |
Sensitivity | ISO 125-6400 (in Auto mode) Max. ISO Speed in P mode is ISO 12800 |
Light Metering Method | Evaluative, Center Weighted Average, Spot |
Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock |
Exposure Compensation | Still Images: ±3 stops in 1/3-stop increments Videos: ±3 stops in 1/3-stop increments (not available during shooting) |
White Balance Control | Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater WB, Kelvin Settings, Custom 1-2 |
Built-in Flash | Auto, On, Slow Synchro, Off |
Flash Range | 1.6 ft. (50 cm) - 23 ft. (7.0 m) (W), 1.3 ft. (40 cm) - 13 ft. (4.0 m) (T) Image brightness may diminish depending on the shooting distance |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
Shooting Modes | C, M, Av, Tv, P, Hybrid Auto, Auto, Self Portrait, Portrait, Panning, Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie, Handheld Night Scene, High Dynamic Range, Fish-eye Effect, Art Bold Effect, Water Painting Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Grainy B/W, Underwater, Fireworks, Standard Movie, Short Clip, Manual Movie, Time-Lapse Movie, iFrame Movie |
Self Timer | Off, 2 sec., 10 sec., Custom |
Wireless Control | Wi-Fi® / NFC |
Continuous Shooting | One Shot H: Approx. 8.0 shots/sec. (max. 30 shots) One Shot L: Approx. 4.0 shots/sec. Servo H: Approx. 5.4 shots/sec. (max. 46 shots) Servo L: Approx. 4.0 shots/sec. |
Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards |
File Format | Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible |
Image Recording Format | Fine / Normal |
JPEG Compression Mode | Still Image: Exif. 2.3 (JPEG), RAW (Canon original: 14-bit, CR2) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo)) |
Number of Recording Pixels |
Description | List/Play Digest Movies, Story Highlights, Protect, Favorites, Erase, Image Search, Slideshow, Rotate, Album Playback, Short Clip Mix, Resize, Cropping, Red-Eye Correction, Face ID Info, Creative Filters, RAW Image Processing, Photobook Set-up, Image Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump with Control Ring/Front Dial, Set Touch Actions, Playback Information Display |
Audio Out | Stereo |
Other | Direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-13L, Battery Charger CB-2LH In-Camera Charging via USB Cable available through Compact Power Adapter CA-DC30* (Charging time: Approx. 5 hrs.)** * To use CA-DC30, IFC-600PCU is necessary. ** Charging time varies considerably depending on the remaining battery power. |
Shooting Capacity | Approx. 265 shots with Screen On (CIPA compliant) Approx. 355 shots with ECO Mode |
Playback Time | Approx. 5 hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.15 x 2.40 x 1.65 in. / 105.5 x 60.9 x 42.0mm |
Weight | Approx. 11.3 oz. / 319g (including battery and memory card) Approx. 10.4 oz. / 294g (camera body only) |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
Wireless API | Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
Title
Canon Support | Firmware Notice: PowerShot G7 X Mark III: Firmware Version 1.1.0
Title
Canon Support | Service Notice: Picture Style File Registration
Title
Canon Support | Firmware Notice: PowerShot G7X Mark II: Firmware Version 1.0.1.0
Title
Canon Support | Firmware Notice: PowerShot G7 X Mark II: Firmware Version 1.1.0
Title
Firmware Notice: PowerShot G7X Mark II: Firmware Version 1.2.0.0
Title
To Users of the Compact Digital Camera PowerShot G7 X Mark II
ADDITIONAL SUPPORT
CONTACT US
