Canon Support for PowerShot G2 | Canon U.S.A., Inc.
PowerShot G2
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact Digital Still Camera with Built-in Flash and 3x Optical Zoom Lens. Lens and Flash accessories available. |
Image Capture Device
Type | 1/1.8-inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 4.1 million |
Effective Pixels | Approx. 4 million |
Lens
Focal Length | 7-21mm (35mm film equivalent: 34 - 102mm) |
Digital Zoom | 3.6x (Maximum 11x digital zoom is available when combined with optical zoom.) |
Focusing Range | Normal AF: 70cm (2.3ft.) - infinity Macro AF: 6cm (0.2ft.) (wide-angle) / 20cm (0.7ft.) (telephoto) - 70cm (2.3ft.) Manual focus: 6cm (0.2 ft.) (wide-angle) / 20cm (0.7 ft.) (telephoto) - infinity |
Autofocus System | TTL autofocus (Continuous or Single), AF lock and Manual focus are available. |
Viewfinders
Optical Viewfinder | Real-image optical zoom viewfinder |
LCD Monitor | 1.8-inch low-temperature polycrystalline silicon TFT color LCD |
LCD Pixels | 113,578 dots (521 (H) x 218 (V)) |
LCD Coverage | Approx. 97% |
Aperture and Shutter
Maximum Aperture | f/2.0 - f/8.0 (wide-angle), f/2.5 - f/8.0 (telephoto) |
Shutter Speed | 15 - 1/1,000 sec. Slow shutter of 1.3 sec. and more operates with noise reduction. |
Exposure Control
Sensitivity | Auto, or user-set ISO 50, 100, 200 or 400 equivalent (At Auto setting, camera automatically adjusts sensitivity in the range of ISO 50 to ISO 100 equivalent.) |
Light Metering Method | Evaluation metering, Center-weighted average metering or Spot metering. |
Exposure Control Method | Program AE, Shutter priority AE, Aperture priority AE or Manual exposure control; AE lock is available. |
Exposure Compensation | +/- 2.0EV in 1/3-stop increments. |
Auto Exposure Bracketing | (AEB) is available. |
White Balance
White Balance Control | TTL Auto White Balance, Pre-set White Balance (available settings: Daylight, Cloudy, Tungsten, Fluorescent , Fluorescent H or Flash) or Custom White Balance |
Flash
Built-in Flash | Operation modes: Auto, Red-Eye Reduction Auto, Red-Eye Reduction ON, flash ON or OFF |
Flash Range | WIDE: 0.7-4.5m (2.3-14.7 ft) TELE: 0.7-3.6m (2.3-11.8 ft)(When sensitivity is set to ISO 100 equivalent) |
Recycling Time | Approx. 10 sec. or shorter. |
Terminals for External Flash | Sync-terminals at accessory shoe. Use of following external flashes is recommended: Canon Speedlite 220EX, 380EX, 420EX, 550EX and Macro Ring Lite MR-14EX. |
Flash Exposure Compensation | +/- 2.0EV (at every 1/3-stop) |
Shooting Specifications
Shooting Modes | Creative zone: Program, Shutter priority, Aperture priority and Manual Image zone: Pan-focus, Portrait, Landscape, Night Scene, Photo Effect (Black & White, Sepia, Neutral Color, Vivid Color), Stitch Assist and Movie |
Self Timer | Operates with approx. 10 seconds countdown. |
Wireless Control | Shooting and playback are available. When shooting, image is captured 2 seconds after shutter release operation. Computer-connected Shooting Available (using included "Remote Computer" software. USB connection to compatible computer required). |
Continuous Shooting | High Speed: Approx. 2.5 images/sec., Normal: Approx. 1.5 images/sec.(at Large/Fine mode and LCD viewfinder is OFF) |
Image Storage
Storage Media | CompactFlash (CF) card (Type I or Type II) |
File Format | Design rule for Camera File system (DCF*1) |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still image: JPEG or CCD-RAW Movie: AVI (Image data: Motion JPEG, Audio data: WAVE [monaural]) |
JPEG Compression Mode | Super Fine, Fine or Normal |
Number of Recording Pixels | Still image: Large: 2,272 x 1,704, Medium High: 1,600 x 1,200, Medium Low: 1,024 x 768, Small: 640 x 480 Movie: 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data | These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
Movie data | Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images), Magnification (approx. 2.5x or 5x on built-in LCD monitor) or Slide Show |
Erasing Specifications
Erase Modes | Single Image, All Images |
Interfaces
Computer Interface | Universal Serial Bus (USB) |
Video Out | Audio/Video Output (NTSC or PAL selectable, monaural audio) |
Other | CF card slot (complied with CF Type II standard). Direct connection to Canon CP Printers (no computer required). |
Power Supply | 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512). 2. AC adapter (type: CA-560) 3. Car battery adapter (type: CR-560) (option)Approx. 400 images (under Canon's standard conditions*2 with full-charged battery)Approx. 300 minutes (under Canon's standard conditions*3 with full-charged battery) |
Power Source | 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512). 2. AC adapter (type: CA-560) 3. Car battery adapter (type: CR-560) (option) |
Shooting Capacity | Approx. 400 images (under Canon's standard conditions*2 with full-charged battery) |
Playback Time | Approx. 300 minutes (under Canon's standard conditions*3 with full-charged battery) |
Physical Specifications
Operating Temperature | 32-104°F (0-40°C) |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.8 x 3.0 x 2.5 in. /120.9 x 76.6 x 63.8 mm (excluding protruding parts) |
Weight | Approx. 14.8 oz./425g (camera body only) |
Computer System Requirements
Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.6 through 9.1 (Please see our Mac OS X Compatibility Statement )CPU: Power PC Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook).RAM: 20MB and over for application |
PC Requirements | Hardware: IBM PC/AT compatible OS: Windows 98 (including the Second Edition), Windows 2000, Windows ME,Windows XP (Please see our Windows XP compatibility statement)CPU: Pentium 150 MHz and over, Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RAM: 32MB or more (Windows 98)RAM: 64MB or more (Windows 2000/Windows ME) |
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronics and Information Technology Industries Association (JEITA). *2 Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23 Celsius degrees). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 seconds intervals. Use flash at every 4-time shootings. Turn camera off and on at every 8-time shootings. *3 Canon's standard conditions of measuring playback time are as follows: Normal temperature (23 Celsius degrees). Repeat playback automatically at a speed of 1 image per 5 seconds. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
