Canon Support for PowerShot A70 | Canon U.S.A., Inc.
PowerShot A70
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 11.22.07
File Size 8.89 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 1.56 MB
Date 04.19.10
File Size 757.0 KB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 3x Optical/3.2x Digital/10x Combined Zoom
Image Capture Device
Type 1/2.7 inch charge coupled device (CCD)
Total Pixels Approx. 3.2 Million
Effective Pixels 3.0 Million
Lens
Focal Length 5.4 - 16.2mm zoom lens (35mm film equivalent: 35 - 105mm)
Digital Zoom 3.2x
Focusing Range Normal AF: 46cm/ 1.5 ft. - infinity
Macro AF: 5 - 46cm/ 2.0 in. - 1.5 ft. (wide-angle), 26 - 46cm/10 in. - 1.5 ft. (telephoto)
Manual focus: 5cm/ 2.0 in. - infinity (wide-angle), 26cm/10 in. - infinity (telephoto)
Autofocus System Around most of picture area
AF lock and Manual focus are available
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.5 inch low temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 78,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 - 4.8
Shutter Speed 15 - 1/2,500 sec.
Slow shutter speed of 1.3 sec. is only available in select modes
Exposure Control
Sensitivity AUTO/ISO 50/100/200/400 equivalent
Light Metering Method Evaluation/Center-weighted average/Spot
Exposure Control Method Program AE/Manual
Exposure Compensation +/-2 EV in 1/3-stop increments
Auto Exposure Bracketing Not Available
White Balance
White Balance Control TTL Auto White Balance, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash), or Custom
Flash
Built-in Flash Operation Modes: Auto/ON/OFF, Red-Eye Reduction, Red-Eye Reduction ON/OFF
Flash Range WIDE: 46 - 4.2m
TELE: 46 - 2.5m
MACRO: 26 - 46cm (When sensitivity is set to ISO 100 equivalent)
Recycling Time Approx. 10 sec. or less
Flash Exposure Compensation Not Available
Shooting Specifications
Shooting Modes Auto, Creative (P, Av, Tv, M, Custom 1, Custom 2), Programmed Image Control Zone, Image (Portrait, Landscape, Night Scene, Stitch Assist, Movie)
Photo Effects Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down
Wireless Control Not Available
Continuous Shooting Approx. 2.2 frames/ sec.
Image Storage
Storage Media CompactFlash (CF) Card Type I
File Format Design rule for Camera File system (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels 2,048 x 1,536 (Large), 1,600 x 1,200 (Medium 1), 1,024 x 768 (Medium 2), 640 x 480 pixels (Small)
Movie: 640 x 480, 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Individual movie clips are limited to 3 minutes maximum per clip. Above figures show total movie capacity on various CF cards, measured under Canon's standard test conditions, and may vary depending upon scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Index (9 thumbnails), Magnification (2x to 10x), Movie, Slide Show
Erasing Specifications
Erase Modes Single Image, All Images, Movie: Part of movie, All movie
Interfaces
Computer Interface Universal Serial Bus (USB) (mini-B jack)
Video Out NTSC or PAL
Other CF card slot (accept type I and type II cards). Direct connection to Canon CP Printers and Direct Photo Printers (no computer required)
Power Supply 1. Size AA Alkaline battery x4
2. Rechargeable size AA NiMH battery x4 (NB-1AH)
3. Compact Power Adapter (ACK-600)Approx. 250 shots/ Approx. 800 shots (LCD monitor ON)
Approx. 350 shots/ Approx. 1000 shots (LCD monitor OFF)(Alkaline battery/ NB-1AH)Approx. 280 min/ Approx 280 min. (Alkaline battery/ NB-1AH)
Power Source 1. Size AA Alkaline battery x4
Shooting Capacity Approx. 250 shots/ Approx. 800 shots (LCD monitor ON)
Playback Time Approx. 280 min/ Approx 280 min. (Alkaline battery/ NB-1AH)
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 3.98 x 2.52 x 1.24 in./101.0 x 64.0 x 31.5mm (Excluding protrusions)
Weight Approx. 7.58 oz./215g (Camera body only)
Computer System Requirements
Mac Requirements OS: Mac OS 9.0-9.2, Mac OS X (v10.1/10.2/10.3). Computer Model: The above OS should be pre-installed on computer with built-in USB ports. CPU: PowerPC. Interface: USB (Models with Apple genuine USB interface only).
PC Requirements OS: Microsoft Windows 98 (including Second Edition)/Me/2000/XP. Computer Model: The above OS should be pre-installed on computer with built-in USB ports. CPU: Pentium 150MHz or higher processor (Windows 98/ Me/2000), Pentium 300MHz or higher processor (Windows XP). Interface: USB (Windows 98/Me/2000/ XP pre-install model only).
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronics and Information Technology Industries Association (JEITA).
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
