Canon Support for plotWAVE T30/T35 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.18.24
File Size 3.67 MB
1-roll (standard) or 2-roll printing system Productive large format monochrome printer with ClearConnect multitouch user panel.
Stacking system Integrated Top Delivery Tray. Up to 100 sheets E-size/A0.
Tilt and Swivel ClearConnect multitouch user interface Consistent look and feel from every angle of your workflow, standard, including Smart Inbox, SmartAccess, and Live Preview.
Roll media switching Fully automated roll media switch to guide the media to the Top Delivery Tray or back output depending on the user application.
ClearConnect workflow software Drivers: Driver Select for Microsoft Windows, Driver Express PostScript 3 driver.
Publishers: Publisher Mobile for IOS and Android, Publisher Express, Publisher Select 3 for Microsoft Windows.
Starter kit included 1 bottle toner 500 g, 1 bottle developer 1750 g, 1 roll 36 inch 20 lb. bond paper (75 g/m2).
Earthquake provision1 Help secure the printer against moving or tilting during an earthquake. This provision enables the user to secure the printer to a sturdy connection of the building.
Office space saving scanning system Scanner Express with Image Logic technology, integrated scanner positioned on top of the printer to save office space.
Stacking systems Stacker Select, 400-sheet capacity
Roll media capacity upgrade 2-roll option doubles media capacity from 1,950 to 3,900 sq. ft. (182 to 365 m2).
Removable hard disk For secure environments, hard disk can easily be removed from the printer system to help secure data integrity.
Imaging technology Electrophotography (LED) with Organic photoconductor (OPC).
Radiant Fusing Technology with instant warm-up. Clean toner refill system.
Virtually no ozone emission.
Fusing technology Instant warm-up, contactless fusing, low power consumption (heating on-demand).
Toner/type Black toner: 1,000 g per toner kit (500 g per toner bottle).
Speed (print and copy) plotWAVE T30: 4-D/A1-sizes2 per minute 2-E/A0 sizes3 per minute
plotWAVE T35: 6-D/A1-sizes2 per minute 3-E/A0 sizes3 per minute
First print out time4 <40 seconds
First copy out time5 <40 seconds
1 Excluding cable/chain and mounting material.
2 D-size (34"" x 22"") / A1 size (841 x 594 mm).
3 E-size (36"" x 48"") / A0 Size (841 x 1189 mm).
4 One A1 landscape print made from the smart inbox, on 64 g media, back output, lines, and text mode.
5 One copy made with A1 original in landscape on 64 g media, back output, background compensation off, custom width 841 mm, custom length 594 mm.
Print resolution 600 x 1200 dpi
Minimum line width (ISO/IEC 13660:2001E) 0.00236" (0.06 mm)
1:1 Line accuracy < 0.3%
Size main engine (WxDxH) 61.6" x 31.7" x 59.2" (1563 mm x 803 mm x 1503 mm) (Height of 59.2" includes Top Delivery Tray)
Shipping dimensions (WxDxH) 58 " x 34 " x 50 " (1470 x 850 x 1280 mm)
Weight main engine 485 lb. (220 kg)
Shipping weight main engine 597 lb. (271 kg)
Media capacity 1 or 2 rolls; manual feed of cutsheet media
Paper cutting Cutter included in the drawer for fast and easy roll media switching.
Maximum media capacity 1 roll (650' L x 36" W): 1,950 sq. ft. If 2 rolls: 3,900 sq. ft.
Media sizes roll ARCH: B, C, D, E, E1, 30"", 21"", 15"" ANSI: B, C, D, E
ISO: A3, A2, A1, A0, B1, B2, B1_700, B2_700
Media sizes Cutsheet tray Short-edge feed (portrait): A3, B4, A, B, A+, B+, Carto B4, 230 x 310 mm, 310 x 440 mm
Long-edge feed (landscape): A3, A2, B4, B3, B, C, B+, C+, Carto B4, Carto B3, 15"" x 21"", 310 x 440 mm, 440 x 594 mm
Media weight Bond: 16-28 lb.(60-110g/m2). Film: 3.5 mil.
Roll length Up to 650' (200 m)
Roll width 11"-36"
(11",12",15",17",18",21",22",24",30",34",36")
(279-914mm)
Minimum printed length 16.5" (420 mm)
Maximum printed length 650' (200 m)
Roll media type Paper: Engineering Bond, Vellum, Recycled Bond, Tinted Bond Xtreme #27 Bond Film: Polyester 3.5 mil
Cutsheet media type Paper: Engineering Bond, Recycled Bond, Tinted Bond Xtreme #27 Bond
Automatic roll media handling Automatic width detection Automatic roll media selection for optimized productivity and media saving, based on drawing size, media type, roll width, and finishing.
Automatic roll switching when end of roll is reached.
Description ClearConnect multitouch user panel
Size (WxDxH) 11.8" x 8.7" x 1.6" (300 x 220 x 40 mm), 10.4" (diag.) color LCD
Resolution 800 x 600 pixels (SVGA)
Technology Projective capacitive touch
Operation 3 hard buttons: [Wake-up], [Stop, interrupt, abort], [Home] Multitouch functions: tap, double tap, pinch, 2-finger pinch, swipe, flick, and spread.
Interface design Distinctive user interface with intuitive navigation and clearly defined levels of operation.
Features View optimization: Tilt ClearConnect (-4 to +45 degrees) and swivel (-45 to +180 degrees). Status light (red, orange, green). USB 2.0 interface with indication light. Switch instantly between 2 languages, select from 21 languages.
Description High performance POWERsync controller with Windows® 10 iOT LTSC21
Processor Dual Core, Dual Thread Celeron® G4900 at 3.10GHz
Memory 2 8 GB DDR4, for a total of 16 GB of memory
Video Intel HD Graphics, 1GHz
Hard disk 500 GB, 7200 rpm (standard)
TPM TPM2.0
Client operating system support Windows 7 / Windows 7 64 bits / Windows 8.1 / Windows 8.1 64 bits / Windows 10 / Windows 10 64 bits / Windows 11 / Windows Server 2008 R2 64 bits / Windows Server 2012 64 bits / Windows Server 2012 R2 64 bits/Mac OS 10.10 / Mac OS 10.11 / Mac OS 10.12 (PostScript 3 driver support only for Mac OS )
Interface 2x Ethernet 100 Mbits/s, 1Gbit/s TCP/IP: DHCP, IPv4, IPv6, HTTPS Discovery: APIPA, WS-Discovery, SNMPv3
Page description language TIFF, JPEG, HPGL, HPGL2, DWF, C4, Calcomp 906/907/951, CALS, NIRS, NIFF, PS/PDF (optional)
Printing protocol LPR, FTP, WebDav, WSD print FTP Pull from SMB, FTP
Pull from cloud (retrieve from WebDAV based clouds) HTTP/HTTPS (used by Publisher Express)
Print from home folder via optional access management
Backchannel protocol SNMPv3, Wave interface, WS-Discovery
New Set of Security Features E-shredding, IPSec, IP filtering/Access Control Lists, HTTPS, SNMPv3, audit logging, AES256 Disk Encryption, 802.1x Authentication, network protocol enable/disable, LDAP integration, Active Directory Integration, User authentication on local ClearConnect user panel and via Express WebTools (LDAP/Active Directory credentials, smart card) for scan/copy/print. Configure HTTPS Certificates. Allow disabling TLS1.0 and 1.1 protocols (no response to network scan) and enable TLS 1.2 with stronger cipher. Embedded FIPS 140-2 Certified Trusted Platform Module (TPM) and BitLocker 256 AES hard disk encryption, hard disk wipe, Configurable CA certificate, Disable Network Ports and Protocols, Security Event Logging, Single Sign-on. Options: Removable hard disk, McAfee antivirus, McAfee Application control (whitelisting).
Access management Help provide secure access to device by users keying in password on the ClearConnect multitouch operator panel or get access with a Smart Card by connecting a card reader (including contactless). Authorization is managed by using Active Directory.
Cloud support Unlimited user and/or Administrator authenticated cloud support via WebDAV and/or third-party provider: e.g. Microsoft SharePoint, Dropbox, Box.com, box.net, Google Drive, Microsoft OneDrive, Amazon Cloud Drive, Cloudsafe, MyDisk. The cloud user authentication can either be preconfigured by the administrator or done by the user at the time of accessing the specific cloud.
Transformations Scaling (scale-to-fit page, reduce when image too large to avoid clipping or to custom factor, scale page size to standard size), Rotation, Shift (automatic or user defined), Adding/removing trailing/leading edge, Mirror, Black intensity in poster mode, Print optimization (standard, lines/text, poster). Color Highlight and Dark Original. Area to erase (area of interest).
Description Integrated Contact Image Sensor (CIS) Color scanner with Image Logic technology
Scan resolution 600 x 600 dpi
Scan speed Monochrome Scanning: Up to 10 inches/second
Copying: Up to 6 inches/second
Color Scanning: Up to 3 inches/second
Scan formats TIFF, PDF, PDF/A, JPEG, CALS, multipage PDF, multipage PDF/A and multipage TIFF
Scan templates Extensive number of scan templates to standardize common scan settings and destinations
Scan protocol FTP, SMB, scan to cloud (push to WebDAV based clouds)
Scan destination Local USB flash drive, FTP, SMB, Smart Inbox on Controller, Optional Local Home folder (LDAP), mobile device via Mobile WebTools, WebDAV Clouds.
Scan naming Preset naming with auto numbering for productive scanning or file name on the ClearConnect user panel
Original width 8.2"-36" (208-914 mm), automatic width detection
Original length 8.2"-52.5" (208 mm-16 m), auto length detection
Original thickness Maximum 0.03" (0.8 mm) non-rigid documents
Zoom (copy) 1:1, Scale to media size, Scale to standard format. Custom: 10-1,000%
Original type presets Lines & Text standard, Folded Lines & Text, Lines & Text draft, Dark Original, Colored Original, Photo, Blueprint, Map, Artwork
Scanner size (WxDx H) 43" x 12" x 5.5" (1,097 x 308 x 140 mm)
Scanner weight 55 lb. (25 kg)
Acoustic sound power Standby and sleep: less than 26 dB. Print mode: less than 52 dB
Ozone concentration < 0.001 mg/m3, < 0.000473 PPM (0.05% of permitted limit value)
Heat emission Ready: 66 W; Active: 1.5 kW
Power requirements 100-240 V; 50/60Hz
Power consumption Sleep mode: <2 W Ready mode: 66 W Active mode: 1.7 kW
Safety/EMC marks and environmental labels CE, TUV GS, CETECOM, Energy Star 3.0, FEMP, Rohs, CCC, VCCI TÜV GS, c-UL-US, CB, RCM, EAC, FCC Class A, VCCI Class A
Recyclables Printer: made of steel or highly recyclable plastics: up to 95% of the engine can either be upcycled or recycled. Remaining 5% are nontoxic waste.
Prints: very good deinkability when recycled.
Toner: bottles made of highly recyclable HDPE (High Density Polyethylene)
Job submission The ClearConnect software suite consists of a variety of applications with the same user interface. Create, retrieve, and/or send jobs from drivers (Driver select for Microsoft Windows, Driver Express for Adobe PostScript 3 for Microsoft Windows or Apple OS), external locations (SMB, FTP, LPR, WebDAV), Mobile devices via Express WebTools and Publisher Mobile, USB flash drive, Cloud services, and optional Home folder (LDAP).
1-click printing from USB, 1-click printing from previous sent jobs via Print SmartAccess on ClearConnect user panel. The Smart Inbox on the ClearConnect user panel enables the job preview: swipe between your jobs for print selection and preview. Pan to view the image in detail (zoom).
With the template-oriented Publisher Select 3 submitting multiple files in batches is supported. Print multiple times and sort by page or set. Media saving automatically rotates print files to optimize media usage.
Smart inbox Personalized Smart Inbox: History, Manage Queue, Manage History, Express WebTools, Secured Controller Access
Queue management Spool memory provides a queuing system for print and copy jobs. This enables multiple users to send print and copy jobs at the same time. Customize priority settings for copy and print jobs in the queue.
The Job Queue overview gives access to job names, owners, and status including required media. Jobs can be paused, deleted, and placed on top of the queue.
Print management and accounting View the counter history at preferred time periods, per job or total overview in Express WebTools. View, create, edit, and delete stamp templates.
Optional uniFLOW support, log in with your personal uniFLOW Queue on the ClearConnect User interface. Supports manual authentication, card readers, and contactless card readers.
Device management Express WebTools provide administrators the tools to manage the device remotely via the web: e.g. check printer status; define settings for print, copy, and scan; define access; security; accounting; remote shutdown; software update and restart; power on/off timer; system behavior; queue management; license management; view, create, edit, and delete stamp templates; etc.
Scan to color inkjet Scan directly to select imagePROGRAF series models via Publisher Select 3 (hotfolder)
Description Integrated productive stacker with high capacity and tray full sensor
Capacity 400 pages
Canon PlotWave T30/T35
Limited Warranty
Canon U.S.A., Inc. (“Canon”) warrants the Canon PlotWave T30/T35 products (“Product”) to be free from material defects in workmanship and material under normal use and service for a period of ninety (90) days after delivery to the original end user customer (“Customer”), or for the first 15,000 square feet of output, whichever occurs first. Customer shall give prompt written notice to Canon of any such defect by the last day of the warranty period. In such event and upon receipt of necessary documentation, Canon shall replace, without charge, any defective part with a new or comparable rebuilt part. This warranty shall not extend to consumables such as paper, chemicals, and toner, as to which there shall be no warranty or replacement. Warranty replacement shall not extend the original warranty period of the Product. This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment, and software.
This warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, relocation, mishandling, alteration, electric current fluctuation, or accident, (b) improper use, including failure to follow operating or maintenance instructions or environmental conditions prescribed in Canon's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon who are acting in accordance with Canon's service bulletins, (d) use of supplies or parts (other than those distributed by Canon) which damage the Product or cause abnormally frequent service calls or service problems, or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered. A Product performing to published specifications is not materially defective.
Non-Canon brand equipment that may be distributed with the Product is sold "AS IS" and without warranty of any kind by Canon, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the third-party supplier or producer thereof.
ANY SOFTWARE THAT IS DISTRIBUTED WITH THE PRODUCT HAS AN ASSOCIATED END USER AGREEMENT AND IS LICENSED AND WARRANTED (IF AT ALL) SOLELY ACCORDING TO THE TERMS OF THAT AGREEMENT, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREIN. CANON TAKES NO RESPONSIBILITY, AND AT ALL TIMES CUSTOMER REMAINS RESPONSIBLE, FOR STORAGE OF DATA (IF AND AS APPLICABLE) ON THE PRODUCT’S HARD DISK DRIVE OR SOLID-STATE DRIVE, AND FOR DUPLICATION OR BACK-UP FOR PREVENTION OF LOSS IN THE EVENT OF FAILURE OR OTHER MALFUNCTION OF THE HARD DISK DRIVE.
THE ABOVE WARRANTIES ARE IN LIEU OF ALL OTHER WARRANTIES AND CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES AND CONDITIONS REGARDING MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF A PRODUCT OR ANY ASSOCIATED COMPONENT, AND ALL SUCH OTHER WARRANTIES AND CONDITIONS ARE DISCLAIMED. NO OTHER EXPRESS WARRANTY, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON, ANY SUPPLIER, OR ANY AUTHORIZED SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
NEITHER CANON NOR ITS SUPPLIERS NOR ANY AUTHORIZED SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF, AS APPLICABLE, CANON OR SUCH SUPPLIER OR AUTHORIZED SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA (INCLUDING, WITHOUT LIMITATION, DATA STORED ON THE PRODUCT'S HARD DISK DRIVE), STORAGE CHARGES, OR OTHER SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON OR ITS SUPPLIERS OR ANY AUTHORIZED SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON OR ITS SUPPLIERS OR ANY AUTHORIZED SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SUPPLIER OR AUTHORIZED SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Defective parts must be returned to Canon or a Canon Authorized Service Provider with all necessary documentation and will become the property of Canon.
THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A.
SUPPLIES & ACCESSORIES
