Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.23 MB
Date 01.01.04
File Size 500.84 KB
Date 07.10.07
File Size 919.94 KB
Date 07.11.07
File Size 4.16 MB
Date 01.01.04
File Size 500.84 KB
Date 04.19.10
File Size 3.08 MB
Date 04.19.10
File Size 4.06 MB
Date 04.19.10
File Size 277.0 KB
Date 04.19.10
File Size 230.0 KB
Date 04.19.10
File Size 230.0 KB
Date 04.19.10
File Size 375.0 KB
Date 04.19.10
File Size 196.0 KB
Date 04.19.10
File Size 228.0 KB
Date 04.19.10
File Size 416.0 KB
Date 04.19.10
File Size 359.0 KB
Power Supply (rated) 7.4 V DC (Battery). 8.4 V DC (DC IN)
Power Consumption 3.4 W (using viewfinder), 4.4 W ( using LCD screen.)
Television System EIA standard (525 lines, 60 fields) NTSC color signal
Video Recording system 2 rotary heads, helical scanning system DV system (Consumer digital VCR-SD system) Digital component recording
Audio Recording system PCM digital sound: 16-bit (48 kHz/2ch); 12-bit (32 kHz/4ch)
Image Sensor 1/4" CCD (charge coupled device); approx 1,330,000 pixels (approx. 690,000 effective pixels-tape); (approx. 1,230,000, effective pixels-card)
Tape Format Videocassettes bearing the MiniDV mark
Tape Speed Sp: 3/4 ips (18.81 mm/sec); LP: 1/2 ips (12.56 mm/sec)
Maximum Recording Time (with an 80-min. cassette) SP: 80min; LP: 120 min
Fast Forward/Rewind Time 2 min. 20 sec (with a 60 min cassette)
Lens f/1.8 - 3.0, 16 x power zoom, 4.0-64.0 mm (tape); f/1.8-3.0, 15x power zoom, 4.3-64.0 mm (card)
Focusing System TTL autofocus, manual focusing possible
Focusing System 3 ft. 3 3/8 in./ (1m); 3/8 in. (1cm) on maximum wide angle
Minimum Illumination 0.5 lx using the Night program during tape recording.
Recommended Illumination more than 100 lx
Filter Diameter 37 mm
Viewfinder 0.33 in., color LCD (approx. 113,000 pixels)
LCD Screen 2.5 in measured diagonally (approx. 112,000 pixels
Microphone Stereo electret condenser microphone
DV Terminal Special 4-pin connector (based on IEEE 1394)
Video Terminal 1 Vp-p /75 ohms unbalanced
S-video Terminal 1Vp-p (Y signal), 0.286 Vp-p (C signal)
Audio Terminal Input level: -10 dBV/40 kohm, unbalanced; Output level: -10 dBV, less than 3 kohms, unbalanced
Operating Temperature range 32-104&deg F (0-40&deg C)
Dimensions 3 x 7.3 x 3.6 in (75 x 186 x 92mm)
Weight (not including lens and battery pack) 1.4 lbs (620 g)
Memory Card
Recording Media MultiMediaCard, SD Memory Card
Image Format Design rule for Camera File System (DCF)
Print Order format Digital Print Order Format (DPOP)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
