Canon Support for MultiPASS F50 | Canon U.S.A., Inc.
MultiPASS F50
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
F30 F50 Reference Guide
File Name
User manual for the MultiPASS F50
File Name
MFP F50 Setup
File Name
MFP F50 FAX Guide
SELECT ERROR CODE
Printer
Printing Method | Bubble Jet ink-on-demand |
Print Speed (up to) | Black:17 ppm Color:12 ppm |
Print Resolution (Up to) | Black:600 x 600 dpi Color:2400 x 1200 dpi |
Ink Compatibility | BCI-3Bk Black Ink Tank, BCI-3C Cyan Ink Tank, BCI-3M Magenta Ink Tank, BCI-3Y Yellow ink Tank |
Paper Sizes | Letter, legal, A4, banner paper, U.S. #10 envelopes |
Paper Compatibility | Plain Paper, Envelopes, Canon Specialty Papers - Banner Paper, Glossy Photo Cards, Glossy Photo Paper, High Gloss Photo Film, High Resolution Paper, Photo Paper Pro, Transparencies |
Paper Handling | Plain Paper - 100 sheets Envelopes - 10 Transparencies - 30 sheets |
Paper Weights | 17 lb. - 28 lb. |
Copier
Copy Resolution (up to) | 600 x 600 dpi |
Copy Speed (up to) | 17 cpm |
No. of Copies | Max. 99 copies |
Reduction / Enlargement | 25% - 400% |
Scanner
Max. Resolutions | Optical:600 x 1200 dpi Interpolated:9600 x 9600 dpi |
Color Depth | Color - 36-bit internal, Grayscale - 12-bit internal |
Interface | TWAIN |
Fax
Applicable Line | Public Switched Telephone Network |
Compatibility | G3 |
Data Compression System | MH, MR, MMR, JBIG, JPEG |
Transmission Speed (approx.) | Black & White Approx. 3 seconds/page* at 33.6 Kbps, ECM-MMR, transmitting from memory; Color: Approx. 1 minute/page** at 33.6 Kbps, ECM-JPEG, transmitting from memory |
Memory Capacity | Memory Size Approx. 270 pages* transmitting from memory |
Fax Scanning Speeds (up to) | Approx. 5 seconds/page* |
Fax Resolution | B&W Standard: 203 x98 dpi; B&W Fine: 203 x 196 dpi; ; Color Standard: 200 x 200 dpi |
Document Feeder | 30 pages (at 20 lb. paper) |
Speed Dialing | Automatic dialing (One-touch speed dialing - 12 destinations; Coded Speed Dialing - 100 locations; Group Dialing - Max. 111 destinations). Regular Dialing: Automatic Redialing: Manual Redialing (with Redial/Pause button) |
Receive Mode | Fax only mode; Fax/Tel mode; Manual mode; Answering machine mode; DRPD (Distinctive Ring Pattern Detection) |
Other Features | Sequential Broadcast (Max. 113 destinations); Automatic Reception; Automatic Fax/Tel Switchover; Remote Reception by Telephone; Non-ring reception; ECM Deactivation; DRPD (Distinctive Ring Pattern); Activity Report (after every 20 transactions); Non-delivery report; TTI (Transit Terminal Identification) |
General
OS Compatibility | Windows® 95/98/2000/Me/XP, Windows NT® 4.0 (Sp 4.0 or later) |
System Requirements | Common:CD-ROM drive, 256-color SVGA monitor or greater, Bi-directional IEEE 1284 compatible parallel or USB cable (Windows 98/2000/Me/XP only) Windows:Windows 95/98 and Windows NT 4.0 (SP 4.0 or later) - 90MHz Pentium® processor, 32 MB (64 MB) RAM; Windows Me - 150 MHz Pentium processor, 32 MB (64 MB) RAM; Windows 2000 - 133 MHz Pentium processor, 64 MB (128 MB) RAM; Windows XP - 233 MHz (300 MHz) Pentium processor, 64 MB (128 MB) RAM, 60 MB free hard disk space (150 MB recommended) |
Standard Interface | IEEE 1284 parallel, USB (Windows 98/2000/Me/XP only) |
Software Included | Setup Software/User Guide CD-ROM including: MultiPASS Suite 4.0; ScanSoft® OmniPage® Pro OCR Software |
Dimension (W x D x H) | 17.3"W x 23"D x 12.8"H (with attachments) |
Weight | 27.3 lbs. (with attachments) |
Warranty | 1-year limited warranty (conditions and restrictions apply, see warranty materials for details) |
† Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary. * Based on ITU-T No.#1 Chart (standard mode). ** Based on Canon COLOR FAX TEST SHEET. |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
