Canon Support for imageRUNNER ADVANCE C3530i II | Canon U.S.A., Inc.
![](/etc.clientlibs/canon/clientlibs/clientlib-base/resources/images/image/canon-image-default.webp)
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE C3500i II Series Spec Sheet
imageRUNNER ADVANCE C3530i II | |
MAIN UNIT | |
TYPE | Color Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | 10.1" TFT LCD WSVGA Color Flat-panel |
MEMORY | 3.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB |
INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n) Others Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
PAPER CAPACITY (LTR, 20LB BOND) | Standard: 1,200 Sheets Maximum: 2,300 Sheets |
PAPER SOURCES (LTR, 20LB BOND) | Standard: Dual 550-sheet Paper Cassettes, 100-sheetStack Bypass Optional: Dual 550-sheet Paper Cassettes(CASSETTE FEEDING UNIT-AP1), |
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | Standard: 250 Sheets Maximum: 3,450 Sheets(with External Finisher and Copy Tray) |
FINISHING CAPABILITIES | Standard: Collate, Group With Inner ShiftSorter: Collate, Group, OffsetWith InnerFinisher:Collate, Group, Offset, Staple, Staple-FreeStaple, Staple On Demand With ExternalFinishers: Collate, Group, Offset, Staple, Booklet, Staple-Free Staple, Staple On Demand, Hole Punch(Optional) |
SUPPORTED MEDIA TYPES | PaperCassettes(1/2): Thin, Plain, Recycled, Color, Heavy,Pre-punched, Bond, Transparency, Envelope Stack Bypass: Thin, Plain, Recycled, Color, Heavy,Pre-punched, Labels, Bond, Coated,Transparency, Tracing, Envelope CassetteFeedingUnit-AP1: Thin, Plain, Recycled, Color, Heavy,Pre-punched, Bond, Transparency |
SUPPORTED MEDIA SIZES | PaperCassette 1: Letter, Executive, Statement-R, Envelope[DL, ISO-C5], Custom Size(5-1/2" x 7-1/8" to 11-3/4" x 8-1/2") Paper Cassette2: 12" x 18", 11" x 17", Legal, Letter, Letter-R,Executive, Statement-R, Envelope[No.10 (COM10), Monarch, DL], Custom Size(5-1/2" x 7-1/8" to 12" x 18") Stack Bypass: 12" x 18", 11" x 17", Legal, Letter, Letter-R,Executive, Statement, Statement-R,Envelope [No.10 (COM10), Monarch,DL, ISO-C5], Envelope Custom Size(3-7/8" x 3-7/8" to 12-5/8" x 18"),Custom Size (3-7/8" x 5-1/2" to12-5/8" x 18"), Free Size (3-7/8" x 5-1/2" to12-5/8" x 18") CassetteFeedingUnit-AP1: 12" x 18", 11" x 17", Legal, Letter, Letter-R,Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 12" x 18") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Stack Bypass: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2) Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
PRINT / COPY SPEED (BW AND COLOR) | Up to 30 ppm (Letter) Up to 20 ppm (Letter-R) Up to 15 ppm (Legal) Up to 15 ppm (11" x 17") |
WARM-UP TIME | From Power On: 34 Seconds From SleepMode: 10 Seconds Quick StartupMode: 10 Seconds1 |
DIMENSIONS (W X D X H) | 22-1/4" x 29-1/4" x 45-1/5"(565 mm x 742 mm x 1148 mm)2 |
INSTALLATION SPACE (WXD) | Basic: Stack Bypass + Cassette drawers open:38-1/2" x 44-1/4" (978 mm x 1123 mm)2 FullyConfigured:63-3/4" x 44-1/4" (1620 mm x 1123 mm)3 |
WEIGHT | Approx. 213.9 lb. (97 kg)4 |
PRINT SPECIFICATIONS | |
PRINT RESOLUTION | 1200 x 1200 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
DIRECT PRINT | Available from USB, Advanced Box, Remote UI,and Web Access5 |
SUPPORTED FILE TYPES | PDF, TIFF, JPEG, EPS, XPS |
PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are availableto provide printing from mobile devices or Internet connecteddevices and cloud-based services depending onyour requirements. |
FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts,Andalé Mono WT J/K/S/T (Japanese,Korean, Simplified and Traditional Chinese),6Barcode Fonts7PS fonts: 136 Roman |
OPERATING SYSTEM8 | UFRII/PS: Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016,MAC OS X (10.7 or later) PCL: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016 |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), ProfileSettings, Secured Print, Forced Hold Printing, Watermark,Page Border, Header/Footer, Page Layout, Two-sidedPrinting, Collating, Booklet Printing, Grouping, Mixed PaperSizes/Orientations, Offsetting, Printing on Transparencies,Front/Back Covers, Toner Reduction |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 5.9 seconds (BW) / 8.2 seconds (Color) |
MULTIPLE COPIES | Up to 999 copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, PaperSetting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, InterruptMode, Setting Confirmation/Cancel |
SPECIAL COPY FEATURES | Book to Two Pages, Two-Sided Original, Finishing, Booklet,Job Build, N on 1, Add Cover, Insert Sheets, Different-SizeOriginals, Density Adjustment, Original Type Selection,Transparency Cover Sheets, Page Numbering, Copy SetNumbering, Sharpness, Erase Frame, Secure Watermark,Print Date, Shift, Gutter,Print & Check, Negative/Positive, Repeat Images,Job Done Notice, Mirror Image, Copy ID Card, Multi SheetFeed Detection, Free Size Original, AdjustOne-Touch Color, Color Balance, Area Designation |
SCAN SPECIFICATIONS | |
TYPE | Single-pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | 150 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | BW Original: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2) CL Original: 17 lb. Bond to 58 lb. Cover (64 to 157 g/m2) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows Vista/7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016 |
SCAN RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x100, 150 x 150, 100 x 100 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning (BW/Color): 80 ipm (300 dpi)/51 ipm (600 dpi) Double-sided Scanning (BW/Color): 160 ipm (300 dpi)/51 ipm (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box,Super G3 Fax (Optional), IP Fax (Optional) |
COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x100, 150 x 150, 100 x 100 |
COMMUICATION PROTOCOL | File: FTP, SMB, WebDAVEmail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
FILE FORMAT | Standard: TIFF, JPEG, PDF (Encrypted, Compact,Searchable, Apply Policy, Optimize for Web,PDF A/1-b, Office Open XML (PowerPoint®,Word), Digital Signature (PDF/XPS)Optional: PDF (Trace & Smooth) |
UNIVERSAL SEND FEATURES | Original Type Selection,Two-Sided Original, Book to Two Pages,Different-Size Originals, Density Adjustment, Sharpness, CopyRatio, Erase Frame, Job Build, Delayed Send, Preview, FinishedStamp, Job Done Notice, File Name, Subject/Message, Reply-To, Email Priority, TX Report, Original Content Orientation,Skip Blank Originals, Multi Sheet Feed Detection |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 2 |
MODEM SPEED | Super G3: 33.6 Kbps G3: 14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
FAX FEATURES | Original Type Selection, Two-Sided Original, Book to TwoPages, Different-Size Originals, Density for Scanning,Sharpness, Copy Ratio, Erase Frame, Job Build, Specifyingthe Sender's Name (when sending fax), Sender's Name (TTI),Select Line, Selecting the Telephone Line (when sending fax),Direct Send, Delayed Send, Preview, Finished Stamp, JobDone Notice, TX Report, Multi Sheet Feed Detection |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE(NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential FaxIn-boxes, 30,000 Maximum Pages Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV SupportedClient PC: Windows (Windows Vista/7/8/8.1/10) Concurrent Connections (Max.)SMB: 64WebDAV: 3 (Active Sessions) |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) |
ADVANCED BOX FEATURES | Disabling Advanced Box, Storage Filtering, Authenticationfor Advanced Box Log-in, Search Function, Sort Function,Printing a PDF File with a Password, imageWARE SecureAudit Manager Support |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Universal Login Manager, uniFLOWOnline Express,9,10 User Authentication, Department ID Authentication,Access Management System,Device and Function Level Log-in Optional: uniFLOW |
DATA | Standard: Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection,Hard Disk Drive Encryption(FIPS140-2Validated)Optional: Hard Disk Drive Removal, IEEE 2600.2Common Criteria Certification, DataLoss Prevention (Requires uniFLOW) |
NETWORK | Standard: Encrypted Secure Print, IP/MacAddress Filtering, IPsec, TLS EncryptedCommunication, SNMP V3.0, IEEE 802.1X,IPv6, SMTP Authentication,POP Authentication before SMTP |
DOCUMENT | Standard: Secure Watermark, Encrypted PDF,Encrypted Secure Print, Digital Signatures,Adobe LiveCycle¿ Rights ManagementES2.5 IntegrationOptional: User Signatures, Document Scan Locking |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF Humidity: 20 to 80 % RH (no condensation) |
POWER REQUIREMENTS | 120-127V AC 60 Hz,7.5 A |
PLUG (MAIN UNIT) | NEMA 5-15P |
POWER CONSUMPTION | Maximum: Approx. 1.5 kWh Standby: Approx. 44.1 W Sleep Mode: Approx. 0.8 W11 Typical Electricity Consumption (TEC) Rating: 1.2 kWh |
STANDARDS | ENERGY STAR® CertifiedRated EPEAT® Gold |
CONSUMABLES | |
TONER | GPR-53 Toner12 |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 36,000 Images Color (C,M,Y): 19,000 Images |
FOOTNOTES 1 Time from device power-on to when copy jobs can be programmed. 2 Includes main unit and either Cassette Feeding Unit-AP1, or Cabinet Type-R. 3 Includes main unit and either Cassette Feeding Unit-AP1 or Cabinet Type-R and Staple/Booklet Finisher-AA1. 4 Includes main unit, ADF consumables, and Cassette Feeding Unit-AP1. 5 PDF print from Web sites is supported. 6 Requires the optional PCL International Font Set-A1. 7 Requires the optional Barcode Printer Kit-D1. 8 Other operating systems and environments, including AS/400, UNIX, Linux and Citrix, may be supported. Some solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 9 No charge for this solution; however activation is required. 10 Check for availability. 11 0.8 W sleep mode not available in all circumstances due to certain settings. 12 GPR-53L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 8,500 images. |
