Canon Support for imageRUNNER ADVANCE C350iF | Canon U.S.A., Inc.
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE C350iF |
Type | Color Digital Multifunction Imaging System |
Functions | Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Fax (Up to 1 Line), Scan, Send |
Operation Panel | 7" WVGA Full-Color TFT Screen |
Image Server Memory | Standard: 2 GB RAM Maximum: 2 GB RAM |
Hard Disk Drive | Standard: 80 GB Maximum: 80 GB |
Network Interface Connection | Ethernet 10/100/1000Base-TX |
Other Interface | USB 2.0 x3 (Host), USB 2.0 (Device) |
Special Media Support | Thin [16 lb. Bond (60 to 63 g/m2)], Plain 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Plain 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m2)], Plain 3 [25 lb. Bond to 28 lb. Bond (91 to 105 g/m2)], Recycled 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Recycled 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m2)], Recycled 3[(25 lb. Bond to 28 lb. Bond (91 to 105 g/m2)], Color [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Heavy 1 [29 lb. Bond to 34 lb. Bond (106 to 128 g/m2)], Heavy 2 [35 lb. Bond to 60 lb. Cover (129 to 163 g/m2)], Heavy 3 [61 lb. Cover to 80 lb. Cover [164 to 220 g/m2)], Transparency [32 lb. Bond to 80 lb. Cover (121 to 220 g/m2)], Pre-punched [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Bond [24 lb. Bond (90 g/m2)], Labels [31 lb. Bond to 59 lb. Cover (118 to 160 g/m2)], Envelopes |
Warm Up Time | From Power On: 34 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 10 Seconds** |
Power Requirements | 120 V, 60 Hz, 7.5 A |
Power Consumption | Maximum: 1.5 kW Sleep Mode: 1 W |
Plug | NEMA 5-15 |
Dimension | 24" x 20-1/8" x 24-1/2" (610 mm x 511 mm x 621 mm) |
Installation Space | 33-1/2" x 24-1/2" ( 852 mm x 621 mm) (When the Multipurpose Tray is extended) |
Weight | Approx. 99.2 lb. (45 kg)*** |
Basic Copy Features | Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check |
Special Copy Features | ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date |
Environmental Features | ENERGY STAR® Qualified RoHS Compliant Blue AngelEPEAT® Rated WEEE Directive |
Advanced Box
Advanced Box Features | Store to Remote Advanced Box: Supported Print/View from Remote Advanced Box: Supported |
Memory Media
Standard | Store to USB Memory |
Scan Specifications
Network TWAIN Scan | Standard: Network WIA Scan |
Network Scan Utility | Color Network ScanGear 2 |
Copy/Print Speed (BW/Color)
Letter | Up to 36/36 ppm |
Legal | Up to 29/29 ppm |
Copy Specifications
First Copy Time | As fast as 5.9 Seconds (BW) and 7.4 Seconds (Color) |
Multiple Copies | 1 to 999 |
Copy Exposure | Automatic or Manual (9 Levels) |
Magnification | 25 - 400% (1% Increments) |
Preset Reductions | 25%, 50%, 64%, 78% |
Preset Enlargements | 129%, 200%, 400% |
Standard Paper Capacity | (20 lb. Bond): 550-sheet Paper Cassette 100-sheet Stack Bypass |
Optional | 1 x 550-sheet Paper Cassette 3 x 550-sheet Paper Cassette |
Maximum Paper Capacity | 2,300 Sheets |
Output Paper Capacity | (21 lb. Bond): Standard:250 Sheets Maximum: 500 Sheets (non-stapled with Staple Finisher-S1 attached) |
Output Sizes
Cassette | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 7-1/2" to 8-1/2" x 14") (98.4 mm x 190.5 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)* |
Bypass | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 5-7/8" to 8-1/2" x 14") (98.4 mm x 148 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5) |
Acceptable Paper Weights
Cassette | 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
Bypass | 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2) |
Duplexing
Paper Size | Standard Automatic Trayless Duplexing (Statement to Legal) |
Paper Weight | Up to 60 lb. Cover (163 g/m2) |
Image Reader
Scan Resolution | Up to 600 x 600 dpi |
Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [up to 4.4 lb. (2 kg)] |
Maximum Original Size | Legal (8-1/2" x 14") |
Security Features
Standard | Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), Send to Myself (only), Send to My Personal Folder (only), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, IEEE 802.1x (wired/wireless), SMTP Authentication, POP Authentication before SMTP, HDD Initialize (Up to 9x) HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
Optional | HDD Encryption, HDD Erase Scheduler, Encrypted Secured Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification,♦ imageWARE Secure Audit Manager Express, uniFLOW, AA-Print, Universal Login Manager |
Estimated Toner Yield | BW: 19,000 Copies/Bottle Color (C,M,Y): 21,500 Copies/Bottle (Estimated @ 5% Coverage) |
Feeders
Description | Document Feeder |
Acceptable Originals | Paper Size: Legal, Letter, Statement Paper Weights: 1-sided scanning (single sheet): 13 lb. Bond to 34 lb. Bond (50 to 128 g/m2) 1-sided scanning (multiple sheets): 13 lb. Bond to 28 lb. Bond (50 to 105 g/m2), 2-sided scanning: 17 lb. Bond to 28 lb. Bond (64 to 105 g/m2) |
Scan Method | Duplexing Automatic Document Feeder |
Scanning Speed | Simplex: 36 ipm (300 dpi)/23 ipm (600 dpi) Duplex: 11 ipm (300 dpi)/9 ipm (600 dpi) |
Capacity | (20 lb. Bond): 50 Sheets |
Paper Supply Options
Description | Cassette Feeding Unit-AG1 |
Paper Capacity | 550 Sheets [21 lb. Bond (80 g/m2)] |
Paper Size | Legal, Letter, Statement, Executive, Custom Size [3-7/8" x 7-1/2" to 8-1/2" x 14" (98.4 mm x 190.5 mm to 216 mm x 355.6 mm)] |
Paper Weight | 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
Power Source | From the Main Unit |
Power Consumption | Approx. 25 W |
Dimensions | 16-3/4" x 20-1/8" x 20" (425 mm x 511 mm x 508 mm) |
Weight | Approx. 33.1 lb. (15 kg) |
Description | Cassette Feeding Unit-AH1 |
Paper Capacity | 550 Sheets x 3 Cassettes [21 lb. Bond (80 g/m2) |
Paper Size | Legal, Letter, Statement, Executive, and Custom Size [3-7/8" x 7-1/2" to 8-1/2" x 14" (98.4mm x 190.5mm to 216mm x 355.6mm)] |
Power Consumption | Approx. 35W |
Dimensions | 16-3/4" x 20-1/8" x 20" (425mm x 511mm x 508mm) |
Weight | Approx. 41.9 lb (19kg) |
