Canon Support for imageRUNNER ADVANCE 615iF III | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
imageRUNNER ADVANCE 715iF III Series Spec Sheet
MAIN UNIT
TYPE
Monochrome Laser Multifunction
CORE FUNCTIONS
Print, Copy, Scan, Send, Fax
PROCESSOR
Canon Dual Custom Processor (Shared)
CONTROL PANEL
10.1" WSVGA Color Touch-panel
MEMORY
3.0 GB RAM
HARD DISK DRIVE
250 GB
INTERFACE CONNECTION
Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 650 Sheets
Maximum: 3,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 550-sheet (CASSETTE FEEDING UNIT-AR1), 2,650-sheet (HIGH CAPACITY CASSETTE FEEDING UNIT-D1), 550-sheet (CASSETTE MODULE-AG1), 75-envelope (ENVELOPE CASSETTE MODULE-A1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard Model: 500 Sheets
Finisher Model: 1,000 Sheets
FINISHING CAPABILITIES
Standard Model: Collate, Group
Finisher Model: Collate, Group, Offset, Staple
SUPPORTED MEDIA TYPES
Cassette (Std.): Thin, Plain, Recycled, Color, Heavy, Labels, Bond, Pre-punched
Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Transparency, Bond, Envelope
Cassette Feeding Unit-AR1 (Optional): Thin, Plain, Recycled, Color, Heavy, Labels, Bond, Pre-punched
High Capacity Cassette Feeding Unit-D1 (Optional): Upper: Thin, Plain, Recycled, Heavy, Color, Labels, Bond, Pre-punched Lower: Thin, Plain, Recycled, Heavy, Color, Bond, Pre-punched
Cassette Module-AG1 (Optional): Thin, Plain, Recycled, Heavy, Color, Labels, Bond, Pre-punched
SUPPORTED MEDIA SIZES
Cassette (Std.): Letter, Executive, Statement, Custom size (3-7/8" x 5-7/8" to 8-1/2" x 11-3/4")
Stack Bypass: Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom size (3" x 5" to 8-1/2" x 14")
Cassette Feeding Unit-AR1 (Optional): Legal, Letter, Executive, Statement, Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14"
High Capacity Cassette Feeding Unit-D1 (Optional) Upper: Legal, Letter, Executive, Statement, Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14" Lower: Legal, Letter
Cassette Module-AG1 (Optional): Legal, Letter, Executive, Statement, Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14"
Envelope Cassette Module-A1: No.10 (COM10), Monarch, DL, ISO-C5
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 36 lb. Bond (60 to 135 g/m2)
Stack Bypass: 16 lb. Bond to 74 lb. Cover (60 to 199 g/m2)
Duplex: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
WARM-UP TIME
From Power On: 10 Seconds1
From Sleep Mode: 10 Seconds2
Quick Startup Mode: 4 Seconds3
DIMENSIONS (W x D x H)
Standard Model: 20-1/4" x 23-5/8" x 24-1/4" (513 mm x 601 mm x 617 mm)
Finisher Model: 20-1/4" x 23-5/8" x 32-1/8” (513 mm x 601 mm x 814 mm)
Dimensions (W x D x H) with Paper Feeding Unit or High Capacity Paper Feeding Standard Model:
25-1/4" x 26-3/8" x 42-1/4" (642 mm x 668 mm x 1073mm)
Finisher Model: 25-1/4" x 26-3/8" x 50” (642 mm x 668 mm x 1270 mm)
INSTALLATION SPACE (W x D x H)
41-3/8" x 32-3/8" (1,052 mm x 823 mm)
WEIGHT4
Standard Model: Approx. 81.6 lb. (37 kg)
Finisher Model: Approx. 101.4 lb. (46 kg)
PRINT SPECIFICATIONS
PRINT / COPY SPEED (BW AND COLOR)
Up to 65 ppm (Letter); Up to 51 ppm (Legal)
PRINT RESOLUTION (dpi)
1200 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT
Available from USB, Advanced Box, Remote UI, and Web Access5
SUPPORTED FILES
PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES
A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.6
FONTS
PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),7 Barcode Fonts8
PS fonts: 136 Roman
OPERATING SYSTEM 9
UFRII/PS: Windows® 7/8.1/10, Windows Server 2008/2008 R2/2012/2012 R2/2016, MAC OS X (10.9 or later)
PCL: Windows® 7/8.1/10, Windows Server 2008/2008 R2/2012/2012 R2/2016
PPD: Windows® 7/8.1/10, MAC OS X (10.3.9 or later)
PRINT FEATURES
Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME
As fast as 5 Seconds
MULTIPLE COPIES
Up to 9,999 Copies
COPY EXPOSURE
Automatic or Manual (9 Levels)
MAGNIFICATION
25%-400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
BASIC COPY FEATURES
Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES
Two-sided Original, Finishing, Job Build, N on 1, Different Size Originals,10 Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy ID Card, Skip Blank Pages, Multi Sheet Feed Detection
SCAN SPECIFICATIONS
TYPE
Single-pass Duplexing Automatic Document Feeder11
DOCUMENT FEEDER PAPER CAPACITY
100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter, Statement, and Custom size (4-1/8" x 5-7/8" to 8-1/2" x 14")
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
BW Original: 12 lb. Bond to 33 lb. Bond (42 to 128 g/m2)
CL Original: 17 lb. Bond to 33 lb. Bond (64 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book, 3-Dimensional Objects [Height up to 1-1/4"; Weight Up to 4.4 lb. (2 kg)]
PULL SCAN
Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows 7/8.1/10/ Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION
600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES
A range of solutions is available to provide scanning to mobile devices or cloud-based services depending on your requirements.
SCAN SPEED (LETTER)
Single-sided Scanning
Color/BW: 50/50 ipm (300 dpi, send)
BW: 50 ipm (600 dpi, copy)
Double-sided Scanning
Color/BW: 100/100 ipm (300 dpi, send)
BW: 100 ipm (600 dpi, copy)
SEND SPECIFICATIONS
DESTINATION
Standard: Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax
Optional: IP Fax
COLOR MODE
Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full Color, Grayscale, and Black-and-White
ADDRESS BOOK
LDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTION
COMMUICATION PROTOCOL
File: FTP (TCP/IP), SMB v3.0, WebDAV
Email: SMTP, POP3
FILE FORMAT
Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b, Encrypted, Device Signature), XPS (Compact, Searchable, Device Signature), Office Open XML (PowerPoint®, Word)
Optional: PDF (Trace & Smooth, User Signature), XPS (User Signature)
UNIVERSAL SEND FEATURES
Original Type Selection, Two-sided Original, Different-size Originals,10 Density Adjustment, Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-To, Email Priority, TX Report, Original Content Orientation, Skip Blank Pages, Multi Sheet Feed Detection
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES
One
MODEM SPEED
Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Legal
FAX MEMORY
Up to 30,000 Pages
SPEED DIALS
Max. 200
GROUP DIALS / DESTINATIONS
Max. 199 Dials
SEQUENTIAL BROADCAST
Max. 256 Addresses
MEMORY BACKUP
Yes
FAX FEATURES
Original Type Selection, Two-sided Original, Density for Scanning, Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Selecting the Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)
100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 7/8.1/10)
Concurrent Connections (Max.)
SMB: 64 WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE
Approx. 16 GB
ADVANCED BOX FEATURES
Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA
Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Universal Login Manager (Device and Function Level Log-in), User Authentication, Department ID Authentication, Access Management System, uniFLOW Online Express12
Optional: uniFLOW
DATA
Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control13
Optional: IEEE 2600 Common Criteria Certification, Data Loss Prevention (requires uniFLOW)
NETWORK
Standard: IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENT
Standard: Encrypted Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Device Signature, Secure Watermark
Optional User Signature
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F
Humidity: 20 to 80% RH (Relative Humidity)
POWER REQUIREMENTS
120-127 V AC 60 Hz, 9.7 A
PLUG (MAIN UNIT)
NEMA 5-15P
POWER CONSUMPTION
Maximum: Approx. 1,500 W
Standby: Approx. 29.77 W14
Sleep Mode: Approx. 1.0 W15
Typical Electricity Consumption (TEC) Rating:  0.68 kWh*
STANDARDS
ENERGY STAR® Certified
Rated EPEAT® Gold16
CONSUMABLES
TONER
T03 Black (All-In-One Toner Cartridge)17
TONER YIELD18 (ESTIMATED @ 5% COVERAGE)
51,500 Images
FOOTNOTES
1 Time from device power-on until copy ready (not print reservation).
2 Time from device power-on to when copy icon appears on the main menu of touch-panel.
3 Time from exiting sleep mode to when printing is operational.
4 Includes consumables.
5 PDF print from Web sites is supported.
6 For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app.
7 Requires the optional PCL International Font Set-A1.
8 Requires the optional Barcode Printer Kit-D1.
9 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
10 Only for Letter/Legal.
11 Detect Feeder Multi Sheet Feeder is supported.
12 No charge for this solution; however activation is required.
13 Requires Unified Firmware Platform v3.9.
14 Reference value (measured one unit).
15 1.0W sleep mode not available in all circumstances due to certain settings.
16 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
17 Includes toner, drum, developer, and waster toner hopper.
18 Toner cartridge yield in accordance with ISO/IEC 19752.
* Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
