Canon Support for imageRUNNER ADVANCE 525iF II | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
imageRUNNER ADVANCE 715iF II Series Spec Sheet
MAIN UNIT
TYPE Monochrome Laser Multifunction
CORE FUNCTIONS Print, Copy, Scan, Send, Fax
PROCESSOR Canon Dual Custom Processor (Shared)
CONTROL PANEL 10.1" WSVGA Color Touch-panel
MEMORY 3.0 GB RAM
HARD DISK DRIVE Stan250 GB
INTERFACE CONNECTION Network: 1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth
Others
Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LTR, 20LB BOND) Standard: 650 SheetsMaximum: 3,200 Sheets
PAPER SOURCES (LTR, 20LB BOND) Standard: 550-sheet Paper Cassette, 100-sheet StackBypass
Optional: 550-sheet (CASSETTE FEEDING UNIT-AR1),2,550-sheet (HIGH CAPACITY CASSETTEFEEDING UNIT-D1), 550-sheet (CASSETTEMODULE-AG1), 75-envelope (ENVELOPECASSETTE MODULE-A1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) 500 Sheets
FINISHING CAPABILITIES Collate, Group
SUPPORTED MEDIA TYPES Cassette (Std.): Thin, Plain, Recycled, Color, Heavy,Labels, Bond, Pre-punchedStack Bypass: Thin, Plain, Recycled, Color, Heavy,Transparency, Bond, EnvelopeCassette Feeding Unit-AR1 (Optional):Thin, Plain, Recycled, Color, Heavy, Labels,Bond, Pre-punched High Capacity Cassette Feeding Unit-D1 (Optional):Upper: Thin, Plain, Recycled, Heavy, Color, Labels,Bond, Pre-punchedLower: Thin, Plain, Recycled, Heavy, Color, Bond,Pre-punchedCassette Module-AG1 (Optional):Thin, Plain, Recycled, Heavy, Color, Labels,Bond, Pre-punched
SUPPORTED MEDIA SIZES Cassette (Std.): Letter, Executive, Statement, Custom size(3-7/8" x 5-7/8" to 8-1/2" x 11-3/4")
Stack Bypass: Legal, Letter, Executive, Statement,Envelope [No.10 (COM10), Monarch,DL, ISO-C5], Custom size (3" x 5" to8-1/2" x 14")
Cassette Feeding Unit-AR1 (Optional):Legal, Letter, Executive, Statement,Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14"
Upper: Legal, Letter, Executive, Statement,Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14"
Lower: Legal, Letter-RCassette Module-AG1 (Optional):Legal, Letter, Executive, Statement,Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14"Envelope
Cassette Module-A1:No.10 (COM10), Monarch, DL, ISO-C5
SUPPORTED MEDIA WEIGHTS Cassettes: 16 lb. Bond to 36 lb. Bond (60 to 135 g/m2)
Stack Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2)
Duplex: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
PRINT / COPY SPEED (BW AND COLOR) Up to 55 ppm (Letter)
Up to 45 ppm (Legal)
WARM-UP TIME From Power On: 30 Seconds1
From SleepMode: 10 Seconds
Quick StartupMode: 4 Seconds2
DIMENSIONS (W X D X H) 20-1/4" x 23-5/8" x 24-1/4"(514 mm x 600 mm x 616 mm)
Dimensions (W x D x H) with Paper Feeding Unit orHigh Capacity Paper Feeding 25-1/4" x 26-3/8" x 42-1/4"(641 mm x 670 mm x 1073 mm)
INSTALLATION SPACE (WXD) 41-3/8" x 32-3/8" (1,052 mm x 823 mm)
WEIGHT3 Approx. 81.6 lb. (37 kg)
PRINT SPECIFICATIONS
PRINT RESOLUTION (dpi) 1200 x 600
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT Available from USB, Advanced Box, Remote UI,and Web Access4
SUPPORTED FILE TYPES PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD A range of software and MEAP-based solutions areavailable to provide printing from mobile devices orInternet-connected devices and cloud-based servicesdepending on your requirements.5
FONTS PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts,Andalé Mono WT J/K/S/T (Japanese,Korean, Simplified and Traditional Chinese),6Barcode Fonts7
PS fonts: 136 Roman
OPERATING SYSTEM8 UFRII/PS: Windows® 7/8.1/10, Windows Server2008/2008 R2/2012/2012 R2/2016,MAC OS X (10.7 or later)
PCL: Windows® 7/8.1/10, Windows Server2008/2008 R2/2012/2012 R2/2016
PRINT FEATURES Suspend Job Timeout, Secured Print, Encrypted SecurePrint, Watermark, Erase Frame, Header/Footer, PageLayout, Two-sided Printing, Collating, Booklet Printing,Grouping, Mixed Paper Sizes/Orientations, Offsetting,Printing on Transparencies, Toner Reduction, PosterPrinting, Job hold printing
COPY SPECIFICATIONS
FIRST-COPY-OUT TIME (LETTER) As fast as 5 Seconds
Copy Resolution (dpi) Reading: 600 x 600
Printing: 2400 x 600
MULTIPLE COPIES Up to 999 Copies
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 78%
PRESET ENLARGEMENTS 129%, 200%, 400%
BASIC COPY FEATURES Preset Reduction/Enlargement Ratios by Area, PaperSetting, Previous Settings, Favorite Settings, Finishing, Two sided,Density Adjustment, Exposure Adjustment, OriginalType Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES Two-sided Original, Finishing, Job Build, N on 1, Different SizeOriginals, Density Adjustment, Original Type Selection, PageNumbering, Copy Set Numbering, Sharpness, Erase Frame,Secure Watermark, Print Date, Shift, Job Done Notice, CopyID Card, Skip Blank Pages, Multi Sheet Feed Detection
SCAN SPECIFICATIONS
TYPE Single-pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY 100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES Legal, Letter, Statement, and Custom size (4-1/8" x 5-7/8"to 8-1/2" x 14")
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT BW Original: 42 to 128 g/m2CL Original: 64 to 128 g/m2
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects [Height up to 1-1/4";Weight Up to 4.4 lb. (2 kg)]
PULL SCAN Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning tomobile devices or cloud-based services depending onyour requirements.1
SCAN SPEED (LETTER) Single-sided Scanning(Color/BW):50/50 ipm (300 dpi);(Color/BW) 30 ipm/50 ipm (600 dpi)
Double-sided Scanning(Color/BW): 100/100 ipm (300 dpi);(Color/BW) 50 ipm/100 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box,Super G3 Fax, IP Fax (Optional)
COLOR MODE Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTION 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,200 x 100, 150 x 150, 100 x 100
COMMUICATION PROTOCOL File: FTP, SMB v3.0, WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF (Compact, Searchable,Apply Policy, Optimize for Web, PDF A/1-b,Encrypted), XPS (Compact, Searchable),Office Open XML (PowerPoint®, Word), PDF/XPS (Digital Signature)
Optional: PDF (Trace & Smooth), PDF/XPS(User Signature)
UNIVERSAL SEND FEATURES Original Type Selection, Two-sided Original, Different-sizeOriginals, Density Adjustment, Sharpness, Erase Frame,Job Build, Sender's Name (TTI), Direct Send, Delayed Send,Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, Email Priority, TX Report, Original ContentOrientation, Skip Blank Originals, Multi Sheet Feed Detection
FAX SPECIFICATIONS
MAXIMUM NUMBER OF CONNECTION LINES One
MODEM SPEED Super G3: 33.6 KbpsG3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Statement to Legal
FAX MEMORY Up to 30,000 Pages
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCAST Max. 256 Addresses
MEMORY BACKUP Yes
FAX FEATURES Original Type Selection, Two-sided Original, Density forScanning, Sharpness, Erase Frame, Job Build, Specifyingthe Sender's Name (when sending fax), Sender's Name (TTI),Selecting the Telephone Line (when sending fax), Direct Send,Delayed Send, Preview, Job Done Notice, TX Report, MultiSheet Feed Detection
STORE SPECIFICATIONS
MAIL BOX (NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential FaxIn-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV
SupportedClient PC: Windows (Windows 7/8.1/10)
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB
ADVANCED BOX FEATURES Disabling Advanced Box, Authentication for Advanced BoxLog-in, Sort Function, Printing a PDF File with a Password,imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard: Universal Login Manager (Deviceand Function Level Log-in), UserAuthentication, Department ID,Authentication, Access ManagementSystem, uniFLOW Online Express9
Optional: uniFLOW and uniFLOW Online
DATA Standard: Trusted Platform Module (TPM), Hard DiskPassword Lock, Hard Disk Drive Erase, MailBox Password Protection, Hard Disk DriveEncryption (FIPS140-2 Validated)
Optional: Data Loss Prevention (Requires uniFLOW)
NETWORK Standard: IP/Mac Address Filtering, IPsec, TLSEncrypted Communication, SNMP V3.0, IEEE802.1X, IPv6, SMTP Authentication, POPAuthentication before SMTP
DOCUMENT Standard: Encrypted Secure Print, Adobe LiveCycle¿Rights Management ES2.5 Integration,Encrypted PDF, Device Signature, SecureWatermark
Optional User Signature
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature: 50 to 86 ºFHumidity: 20 to 80 % RH (no condensation)
POWER REQUIREMENTS 120-127V AC 60 Hz, 9.7 A
PLUG (MAIN UNIT) NEMA 5-15P
POWER CONSUMPTION Maximum: Approx. 1.5 kWh
Standby: Approx. 29.77 W
Sleep Mode: Approx. 0.41 W10
Typical Electricity Consumption (TEC) Rating: 2.1 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold11
CONSUMABLES
TONER T03 Black (All-In-One Toner Cartridge)12
TONER YIELD (ESTIMATED @ 5% COVERAGE)13 51,500 Images
FOOTNOTES
1 Time from device power-on until copy ready(not print reservation).
2 Time from device power-on to when copy icon appearson the main menu of touch-panel.
3 Includes consumables.
4 PDF print from Web sites is supported.
5 For more information, including compatibility, pleasevisit https://www.usa.canon.com/mobile-app.
6 Requires the optional PCL International Font Set-A1.
7 Requires the optional Barcode Printer Kit-D1.
8 Other operating systems and environments includingAS/400, UNIX, Linux and Citrix may be supported. Someof these solutions are chargeable. SAP Device Types areavailable via the SAP Market Place. For more information,contact your sales representative.9 No charge for this solution; however activation is required.
10 0.41 W sleep mode not available in all circumstancesdue to certain settings.
11 For current EPEAT rating (Gold/Silver/Bronze),please visit www.epeat.net.
12 Includes toner, drum, developer, and waster toner hopper.
13 Toner cartridge yield in accordance with ISO/IEC 19752.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
