Canon Support for imageRUNNER 2525 | Canon U.S.A., Inc.
imageRUNNER 2525
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Model Name imageRUNNER 2525
Type Monochrome Digital Multifunction Imaging System Functions
Standard: Copy, Print (UFR II LT), Scan
Optional: Print (PCL, PostScript 3 Emulation), Send (Color Send, Searchable PDF), Fax Operation Panel 5.7" QVGA Black-and-White LCD Touch-Screen
Image Server Memory Standard: 512MB RAM
Maximum: 512MB RAM Network Interface Connection Ethernet 10/100Base-TXOther Interface
Standard: USB 2.0 (Host)x1, USB 2.0 (Device)x1
Optional: USB 2.0 (Host)×3 (USB Application 3-Port Interface Kit-A1), Serial Interface, Copy Control Interface
Letter Up to 25 ppm
Legal Up to 13 ppm
Ledger Up to 15 ppm
First Copy Time 5.4 Seconds (Letter)
Multiple Copies 1 to 999Copy Exposure Automatic or Manual (9 Levels)
Magnification 25% - 400% (1% Increments)
Preset Reductions 25%, 50%, 64%, 73%, 78%
Preset Enlargements 121%, 129%, 200%, 400%Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection Special Copy Features ID Card Copy, Two-page Separation, Image Combination, Frame Erase, Different Size Original, Sharpness, Mode Memory, Booklet
Standard Paper Capacity (20 lb. Bond): Dual 550-sheet Paper Cassettes
100-sheet Stack Bypass
Optional: Dual 550-sheet Paper Cassettes
Maximum Paper Capacity 2,300 Sheets Output Paper Capacity (20 lb. Bond):
Standard: 250 Sheets (Inner Tray)
Maximum: 1,100 Sheets (w/Inner Finisher-B1 and Inner Finisher Additional Tray-B1)
Output Sizes
Cassette Cassette 1/3/4: 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive
Cassette 2: 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Envelopes (COM10 No.10/Monarch/DL/ISO-B5/ISO-C5)*
Bypass 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Envelopes, Custom Size
Acceptable Paper Weights
Cassette 17 lb. Bond to 24 lb. Bond
Bypass 17 lb. Bond to 34 lb. Bond Special Media Support
Cassette 2: Envelopes
Bypass: Transparencies, Labels, Envelopes
Warm Up Time From Power On: 30 Seconds or Less
From Sleep Mode: 1 Second or Less
Power Requirements 120V AC, 60Hz, 6.9APlug NEMA 5-15PPower Consumption Maximum: 1,473W; Sleep Mode: 1W
Dimension (with DADF): 35-1/4" x 22-1/4" x 27-1/4"
(with Platen Cover): 31-3/4" x 22-1/4" x 26-3/4"Installation Space (W x D) 42-1/2" x 56-3/4" (with no optional equipment attached)
54" x 56-3/4" (with optional Inner Finisher-B1 attached)
Weight Approximately 156 lb. (Main Unit)**
Approximately 172 lb. (with DADF)**
Estimated Toner Yield 14,600 Copies/Bottle (Estimated @ 6% Coverage) Scan Specifications
Network TWAIN Scan Standard
Network Scan Utility Color Network Scan Gear Print Features
Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing, Generic PCL 6 Driver Security Specifications
Department ID Management, User ID Management, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book, Address Book Password, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast), SNMPv1, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP Environmental Information EPEAT Silver ENERGY STAR® Qualified RoHS Compliant Ecomark Blue Angel WEEE Directive
Feeders
Description DADF-AB1&bull;
Acceptable Originals 11" x 17", Legal, Letter, Letter-R, or Statement Scan Method: Duplexing Automatic Document Feeder
Scanning Speed (BW/Color; Letter): Copy: 25 ipm (600 dpi)
Scan: 35/25 ipm (300 dpi)
Capacity 50 Sheets (Letter)
Paper Weights 14 lb. Bond to 28 lb. Bond
28 lb. Bond to 34 lb. Bond when scanning a single-page document
Power Source From the Main Unit/Approximately 27.1W (Maximum)
Dimensions 5" x 21-3/8" x 22-1/4"
Weight Approximately 15.4 lb.
Paper Supply Options
Description Cassette Feeding Unit-AE1
Paper Capacity 550 Sheets x 2 Cassettes (20 lb. Bond)
Paper Sizes 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive
Acceptable Paper Type: Plain, Recycled, Color, Pre-Punched
Paper Weights 17 lb. Bond to 24 lb. Bond
Power Source From the Main Unit/Approximately 17.4W (Maximum)
Dimensions 9-3/4" x 22-1/4" x 26-3/4"
Weight Approximately 52.9 lb.
Description Envelope Feeder Attachment-D1&dagger;&dagger;
Paper Capacity 50 Sheets (or 30mm in height)
Paper Sizes (Acceptable Envelope Size:) COM10 No.10, Monarch, DL, ISO-B5, ISO-C5
Print Speed: Up to 10 ppm
SUPPLIES & ACCESSORIES
