Canon Support for imagePROGRAF TX-4200 MFP Z36 | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
Printer Type | 5-Color 36-inch Printer |
Technology | FINE (Photolithography Inkjet Nozzle Engineering) |
Print Resolution (Max.) | 2400 x 1200 dpi |
Line Accuracy(1) | ±0.1% or Less |
Minimum Line Weight(2) | 0.02 mm |
Number of Nozzles | Total: 15,360 MBK: 5,120 nozzles C, M, Y, BK: 2,560 nozzles each |
Ink Type | Pigment: Matte Black (MBK), Cyan (C), Magenta (M), Yellow (Y), Black (BK) |
Ink Tank | Shipped with Printer: MBK/BK/C/Y/M: 330 ml Replacement: M: PFI-111(160ml)/PFI-311(330ml)/PFI-711(700ml) MBK/BK/C/Y: PFI-110(160ml)/PFI-310(330ml)/PFI-710(700ml) |
Nozzle Recovery System | Non-firing Nozzle Detection and Compensation |
Ink Supply Method | Tubing System with Sub Tanks for Continuous Ink Supply |
Printer Controller | L-COA PRO |
Nozzle Pitch (Head Resolution) | 1200 dpi x Two Rows |
Ink Droplet Size | 5 picoliter |
Printer RAM | 128 GB (Virtual) 2 GB (Physical) |
Hard Drive | 500 GB |
Media Width | Cut Sheet: 6-44 (152 mm - 1118 mm) Roll Feed: 6-44 (152 mm - 1118 mm) |
Printable Margins | Roll Feed: All Sides: 0.12" (3 mm) or 0" for Borderless |
Maximum Print Length (Single Page)(3) | Roll Feed: 59' (18 m)Cut Sheet: 63" (1.6 m) |
Borderless Printing Widths (Roll Media Only) | Custom Roll Width 6 - 44 with Micro Margin Technology |
Media Cutter | Automatic horizontal rotary cutter: standard |
Media Thickness | 0.07 - 0.8 mm |
Media Core Sizes | 2 with 3 Core Adapters Included |
Maximum Roll Outer Diameter | 6.7" (170 mm) |
Media Output Options | TX Stacker or Multipositional Catch Basket |
Media Method | Roll Feed: One Roll, Front-loading, Front Output Front Loading Manual Feed: One Roll, Front Output |
Printing Software Utilities | Accounting Manager, Canon Print Service, Canon Production Printing (CPP) Driver Select, Canon Production Printing (CPP) PRISMA Tech Suite, Device Management Console, Direct Print Plus, Free Layout Plus, imagePROGRAF Printer Driver for Windows®/Mac®, Media Configuration Tool, PosterArtist, Optimized Driver for AutoCAD, Quick Utility Toolbox |
Operating System | Windows 7 (32/64-bit), Windows 8.1 (32/64-bit), Windows 10 (32/64-bit), Windows 11 (64-bit), Windows Server 2008R2, 2012, 2012R2, 2016, 2019, 2022 (64-bit), MacOS v10.15.7- MacOS 14 |
Print Languages | SGRaster, HP-GL/2, HP RTL, PDF, JPEG |
Interface | USB B Port Type: Built-in (Hi-speed USB) Mode: Full Speed (12-Mbit/sec.), High Speed (480-Mbit/sec.), Bulk Transfer Connector Type: Series B (4 Pins) USB A Port: Direct USB Thumb Drive Printing Gigabit Ethernet Type: Built-in Standard: IEEE 802.3u 100Base-TX/Auto-Negotiation, IEEE 802.3ab 1000Base-T/Auto-Negotiation, IEEE 802.3x Full Duplex Protocol: SNMP, HTTP, TCP/IP (IPv4/IPv6), FTP Wireless LAN Standard: IEEE802.11n/IEEE802.11g/IEEE802.11b4 Security: WEP (64/128-bit), WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES) |
Acoustic Noise | Operation: 51 dB (A) or Less Standby: 35 dB (A) or Less Acoustic Power: Approx 6.9Bels |
Power Supply | AC 100 - 240 V (50 - 60 Hz) |
Power Consumption | Maximum: Approx. 115 W Standby: Approx. 2.0 W Power Off: Approx. 0.3 W |
Certifications | Electrical Safety Regulations C TUVus (U.S.A.), C TUVus (Canada) Electromagnetic Interface Regulations FCC Part 15B (U.S.A.), IC (Canada) Radio Regulations FCC Part 15C (U.S.A.), IC (Canada) Environmental Certifications ENERGY STAR® (Worldwide) & EPEAT Gold |
Operational Environment | Temperature: 59° F - 86° F (15° C - 30° C) Relative Humidity: 10 - 80% (No Condensation) |
Printer Dimensions (W x D x H) and Weight | With Basket Open: 54.7 x 38.7 x 46; 231.5 lb. (Approx.) With Basket Closed: 54.7 x 30.2 x 46; 231.5 lb. (Approx.) With Stacker Opened: 54.7 x 46.8 x 46; 258 lb. (Approx.) With Stacker Closed: 54.7 x 44.2 x 46; 258 lb. (Approx.) |
Package Dimensions (W x D x H) and Weight | Printer (Main Unit with Stand and Pallet): 64 x 35.6 x 40.7; 337 lb. (Approx.) Basket: 56 x 21.9 x 8.4; 20 lb. (Approx.) Stacker: 49.2 x 35.7 x 11.5; 60 lb. (Approx.) Roll Unit: 60 x 22.1 x 18.1; 68.3 lb. (Approx.) |
Options | Multifunction Roll System (RU-42) 2"/3" Roll Holder Set (RH2-46) User-Replaceable Items Ink Tank (PFI-110/111, PFI-310/311, PFI-710/711) Print Head (PF-06) Maintenance Cartridge (MC-30) Cutter Blade (CT-07) |
Z36 Scanner Specifications | |
Scan Speed(5) | 24-bit Color @ 200 dpi: Up to 3 per second 8-bit Grayscale and Monochrome @ 200 dpi: Up to 13 per second |
Copy Speed | 24-bit Color @ 200 dpi: Up to 6 per second |
Color Space | sRGB |
Maximum Resolution | 1200 dpi (Optical) |
Scan Accuracy(6) | ±0.1% : ±1 pixel |
Maximum Scan Width/Maximum Media Width | 36/38 |
Maximum Scan Length | 164 (PDF); 315 (JPEG); 598 (TIFF) |
Maximum Media Thickness | 0.003 - 0.04 (0.07 mm - 1.0 mm) |
Digital Imaging Technology | Contact Image Sensor (CIS) Technology (SingleSensor Assembly) 24-bit RGB 16-bit grayscale image capture Panchromatic monochrome and black and white Bi-directional extra long-life LED light system for optimum object illumination and instant-on scanning capability |
Included Software | SmartWorks MFP Scan-to-Copy/File/Email with Real-time Image Viewer; supports TIFF, JPEG, and PDF |
Operating System | W11 Enterprise LTSC (x64) |
Scanner Interface Kit | 3x USB 3.2 and 1x USB 2.0 rear and 1x USB 3.2 front, all type A |
Operating Environments | 10°C - 35°C, 10 - 90% RH, Non-condensing |
External Power Supply | 100 - 240 VAC Autosensing +/- 10%, 50 - 60 Hz |
Scanner Power Consumption | Sleep: 0.2 W Idle: 12.4 W Scanning Color/Grayscale at 200 dpi: 22.7 W/23.3 W Controller: 35 W |
Compliances | ENERGY STAR®, CB(62368-1), CE, FCC(EMC), Cul/UL, CCC, NOM-019, EAC, C-TICK, VCCI, BIS, EMC +LOA, UL AR, WEEE, REACH, RoHS, EU - Tier 3 of Lot 6 |
MFP Package Dimensions (W x D x H) and Weight | (With Stand, Pallet, and Scanner) 50" x 17" x 19.5", 75 lb. (Approx.) |
Disclaimers |
CANON imagePROGRAF LARGE FORMAT PRINTER LIMITED WARRANTY |
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon imagePROGRAF Large Format Printer packaged with this limited warranty and Canon branded accessories and options designed for use with the imagePROGRAF Large Format Printer (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty shall not extend to the Canon Printhead for the Product, for which a separate warranty is given. Nor shall this warranty cover other consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement. THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED. ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATION AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT. NEITHER CANON NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE T0 REALIZE SAVINGS OR OTHER BENEFITS, LOSS OR CORRUPTION OF DATA INCLUDING, WITHOUT LIMITATION, DATA STORED ON THE PRODUCT'S HARD DISK DRIVE, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS, ARISING OUT OF THE POSSESSION, USE, MISUSE OR INABILITY TO USE THE PRODUCT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SERVICE PROVIDER. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER, AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY. CONDITIONS OF WARRANTY Defective parts must be returned to Canon or a Service Provider with all necessary documentation and will become the property of Canon. THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A. ONLY. Canon U.S.A., Inc. One Canon Park, Melville, NY 11747 - 3336 |
