Canon Support for imagePRESS C800/C700 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 11.24.14
File Size 95.3 MB
Date 11.24.14
File Size 298.0 KB
Date 12.01.14
File Size 1.35 MB
Date 11.24.14
File Size 2.41 MB
Date 11.24.14
File Size 19.2 MB
Date 09.03.14
File Size 471.0 KB
Main Unit Specs
Model Name
imagePRESS C800/C700 Series
Imaging System
Electrophotography
Printing Resolution
2400 x 2400 dpi
Halftone
256-Level Grayscale
Copy/Print Speed (BW/Color)
Letter
(Simplex / Duplex): C800: Up to 80 ipm
C700: Up to 70 ipm
Legal
(Simplex / Duplex): C800: Up to 46 ipm
C700: Up to 41 ipm
Ledger
(Simplex / Duplex): C800: Up to 40 ipm
C700: Up to 35 ipm
Output Sizes
Cassette
11×17, Legal, Letter, Letter-R, Executive, Statement-R, 12×18, 13×19, Envelope (envelope attachment kit required), Custom Size (3.94x5.83 to 13 x 19.2)
Bypass
(Optional): 11×17, Legal, Letter, Letter-R, Executive, Statement-R, 12×18, 13×19, Envelope, Custom Size (3.94x5.83 to 13 x 19.2)
Acceptable Paper Weights
Cassette
14 lb. Bond to 80 lb. Cover (52 to 220g/m2)
Bypass
(Optional): 14 lb. Bond to 110 lb. Cover (52 to 300g/m2)
Duplexing
Duplexing
Automatic Duplex/Perfect, Any Supported Stock
Paper Size
11×17, Legal, Letter, Letter-R, Executive, Statement-R, 12×18, 13×19, Custom Size (3.94x5.83 to 13 x 19.2) Paper Feeding: Standard: 1,650 Sheets (20 lb. Bond)
Maximum: 7,650 Sheets (20 lb. Bond)
Paper Weight
Special Media Support
Cassette: Thin paper, Plain paper, Recycled paper, Thick paper, Color paper, Transparency, Pre-punched paper, Bond paper, Letterhead, Textured paper, Tab Paper, Envelope (envelope attachment kit required)
Bypass: Thin paper, Plain paper, Recycled paper, Thick paper, Color paper, Transparency, Pre-punched paper, Coated paper, Bond paper, Letterhead, Textured paper, Tab Paper, Envelope
Plug
Single-Phase 208 V/20 A # NEMA 6-20P
Dimension
(H x W x D): 56.1 x 60.2 x 36.8 (Includes operator panel)
Image Reader
Scan Resolution
Up to 600 x 600 dpi
Acceptable Originals
Statement to 11 x 17Scan Speed: 300dpi / 600dpi
BW (Duplex): 200 / 120 ipm
Color (Duplex): 140 / 70 ipm
Accessories
Paper Supply Options
Description
Multi-Drawer Paper Deck-B1
Paper Capacity
6,000 Sheets (20 lb. Bond)
Paper Size
5.5 x 7.2 to 13 x 19.2
Paper Weight
14 lb. Bond to 110 lb. Cover (52 gsm to 300 gsm)
Power Source
120 V/15 A
Dimensions
(H x W x D): 40.9 x 37.4 x 31.4
Description
POD Deck Lite-B1
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Size
5.5 x 5.82 to 13 x 19.2
Paper Weight
14 lb. Bond to 110 lb. Cover (52 gsm to 300 gsm)Envelopes: #10 Business, Monarch, 6 x 9, 9 x 12, 10 x 13
Dimensions
(H x W x D): 22.5 x 28.2 x 27
Description
Stack Bypass-B1
Paper Capacity
100 Sheets (20 lb. Bond)
Paper Size
3.94 x 5.83 to 13 x 19.2
Paper Weight
Output Options
Finishers / Output Trays
Description
Finisher-AM1/Saddle Finisher-AM2
Paper Size
Stapling: Executive, Letter-R, Letter, Legal, 11 x 17
Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19, Custom Size
Paper Weight
14 to 110 lb. Cover (52 gsm to 300 gsm)
Top Tray
1,000 Sheets (20 lb. Bond)
Lower Tray
4,000 Sheets (20 lb. Bond)
Saddle Stitch Tray
30 Booklets or Limitless
Staple Capacity
Up to 100 Sheets
Staple Positions
Corner Stapling, Double Stapling
Booklet Stapling Capacity
Uncoated: Up to 25 Sheets
Coated: Up to 15 Sheets
V-Folding: Up to 5 Sheets without Stitch (20 lb. Bond)
Dimensions
(H x W x D): AM1: 48.8 x 35.0 x 31.2
AM2: 48.8 x 41.7 x 31.2
Description
Staple Finisher-T1/Booklet Finisher-T1****
Paper Size
Staple: Executive, Letter-R, Letter, Legal, 11x17
Saddle: Letter-R, Legal, 11x17, 12x18
Paper Weight
Top/Lower Trays: 14 lb. Bond to 110 lb. Cover (52 to 300g/m2)
Escape Tray: 14 lb. Bond to 140 lb. Index (52 to 256g/m2)
Number Of Trays
3
Top Tray
1,300 Sheets (Letter, Statement-R, Executive)
650 Sheets (13x19, 12x18, 11x17, Legal, Letter-R)
Lower Tray
2,450 Sheets (Letter) 1,700 Sheets (Statement-R, Executive)
650 Sheets (13x19, 12x18, 11x17, Legal, Letter-R) Escape Tray: 250 Sheets (Letter, Statement-R, Executive)
125 Sheets (13x19, 12x18, 11x17, Legal, Letter-R)
Saddle Stitch Tray
Up to 25 Booklets
Staple Capacity
Up to 50 sheets
Staple Positions
16 Sheets [20 lb. Bond (80g/m2)] [including 1 Cover Sheet, up to 140 lb. Index (256g/m2)]
Dimensions
44.1x30.0x25.8 (When the Auxiliary Tray is extended)
Puncher Units
Description
Professional Puncher-B1/Integration Unit-A1
Paper Size
LTR, LTR-Tab Paper
Paper Weight
20 lb. Bond to 80 lb. Cover (75 gsm to 216 gsm)Die Set Patterns: Loose Leaf 3-Hole/5-Hole, Velo Bind 11-Hole, Plastic Comb 19-Hole, Twin Loop 21-Hole/32-Hole, ProClick 32-Hole, Color Coil 44-Hole
Plug
120 V/15 A
Dimensions
(H x W x D): 40.9 x 22.0 x 31.2*
Description
Puncher Unit-BS1/Puncher Unit-BT1 (Option for Finisher/Saddle Finisher)
Paper Size
2-Hole: Letter-R, Custom Size (182 x 182 mm to 297 x 432 mm)
3-Hole (BS1 Only): 11 x 17, Letter, Executive-R, Custom Size (240 x 182 mm to 297 x 432 mm)
4-Hole (BT1 Only): 11 x 17, Letter, Executive-R, Custom Size (257 x 182 mm to 297 x 432 mm)
Paper Weight
14 lb. Bond to 110 lb. Index (52 gsm to 200 gsm)
Description
External 2/3-Hole Puncher-C1 (Option for Staple Finisher-T1/Booklet Finisher-T1)*
Paper Size
11 x 17, Legal, Letter, Letter-R
Paper Weight
Paper Type
Thin, Plain, Heavy, Color, Recycled, Bond, Letterhead, Tab, Textured, Coated
Punch Type
2 Holes: (Legal, Letter-R)
3 Holes: (11 x 17, Letter)
Distance Between Punch Holes
2 Holes: 2-3/4 (70mm)
3 Holes: 4-1/4 (108mm) Punch Waste Tray Capacity: Approx. 10,000 Sheets [20 lb. Bond (80g/m2)]
Power Requirements
From the Main Unit
Dimensions
32.5 x 4.2 x 24.2 (825mm x 107mm x 615mm)
Weight
17 lb
Booklet Trimmers
Description
Booklet Trimmer-D1**
Margin Trimming
Front-edge Trim
Trim Amount
0.08 to 0.78
Trim Thickness
50 Sheets
Paper Weight
Output Tray Capacity
30 Booklets
Dimensions
(H x W x D): 40.9 x 62.1 x 30.3
Description
Two-Knife Booklet Trimmer-A1***
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
