Canon Support for imageCLASS MF543dw | Canon U.S.A., Inc.
imageCLASS MF543dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
Printer Specifications
Printer Type | Black and White Laser |
Print Speed | Up to 45 ppm (Letter); Up to 36 ppm (Legal) 5 |
First Print Time | Approx. 5.6 Seconds |
Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
Print Resolution | 600 x 600 |
Copier Specifications
Copy Speed | Up to 45 ppm (Letter); Up to 36 ppm (Legal) |
Copy Resolution | 600 x 600 |
Warm-up Time | From Power On: 14 Seconds or Less From Sleep Mode: 4 Seconds or Less |
First Copy Time | Approx. 6.0 Seconds |
Reduction/Enlargement | Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
Zoom | 25% - 400% (1% Increments) |
Copy Size | Platen and ADF: Up to Legal |
Copy Features | Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
Fax Specifications
Modem Speed | Super G3: 33.6 kbps G3: 14.4 kbps |
Fax Resolution | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
Memory Capacity | Up to 512 Pages |
Speed Dials | Max. 281 |
Group Dialing | Max. 299 Dials |
Sequential Broadcasting | Max. 310 Addresses |
Fax Features | RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax |
Memory Backup | Yes |
Scanner Specifications
Scan Type | Single-Pass Duplexing Automatic Document Feeder |
Scan Resolution | 300 x 600, 600 x 600 |
Scan Size | Legal, Letter, Statement |
Pull Scan | ScanGear MF for TWAIN, WIA, and ICA |
Paper Handling Specifications
Standard Paper Source(s) | 550-sheet Paper Cassette, 100-sheet Multipurpose Tray |
Optional Paper Source(s) | (up to three): 550-sheet Paper Cassettes (Paper Feeder PF-C1) |
Paper Output | 150 Sheets |
Paper Weight | Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Multipurpose Tray: 16 lb. Bond to 53 lb. Bond (60 to 199 g/m2) |
Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14") |
Media Types | Cassettes: Thin, Plain, Recycled, Color, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Color, Thick, Bond, Label, Envelope (10 Envelopes) |
Connectivity and Software Specifications
WiFi Authentication Methods | Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) Wi-Fi Access Point: WPA2-PSK (AES) |
Mobile Functions | Apple® AirPrint®Canon PRINT Business, Mopria™ Print Service, Google Cloud Print,™ uniFLOW Secure Mobile Printing |
Network Functions | IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
Print Protocols | File: FTP, SMB Email/iFax: SMTP, POP3, iFax (Simple) |
OS Compatibility | Windows® 7/Windows 8.1/Windows 10/ Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016/Windows Server 2019/ Mac OS X v10.9.5 (or later) |
Environmental Specifications
Power Consumption | Maximum: Approx. 1440 W Standby: Approx. 17 W Sleep Mode: Approx. 0.9 W |
Typical Energy Consumption | 0.40 kWh |
General Specifications
Dimensions | 19.5" x 18.3" x 17.8" (494 mm x 464 mm x 452 mm) |
Unit Weight (without/with cartridge) | Approx. 41.9 lb. (19.0 kg) |
Package Weight | Approx. 56.2 lb. (25.5 kg) |
PRODUCT LIMITED WARRANTY
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
