Canon Support for imageCLASS MF462dw | Canon U.S.A., Inc.
imageCLASS MF462dw
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 12.20.23
File Size 476.17 KB
Date 07.20.23
File Size 291.40 KB
Date 09.17.24
File Size 2.27 MB
Date 07.20.23
File Size 405.58 KB
Date 09.17.24
File Size 1.85 MB
Date 09.25.23
File Size 2.27 MB
Date 12.20.23
File Size 1.85 MB
Date 12.20.23
File Size 1.32 MB
Date 07.20.23
File Size 146.85 KB
Date 07.20.23
File Size 154.27 KB
Date 09.17.24
File Size 1.32 MB
Date 07.20.23
File Size 6.06 MB
Date 07.20.23
File Size 4.77 MB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
Products Windows 10 Windows 11
imageCLASS MF462dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF462dw
Products ChromeOS
imageCLASS MF462dw
Model Name imageCLASS MF462dw
Functions Print, Scan, Copy, Fax
Print Speed Up to 37 ppm (Letter)
Document Feeder 50 Sheets Duplex
First Print Out Time Approx. 4.9 Seconds (Letter)
Print/Copy Resolution Up to 1200 x 1200 dpi
Scan Resolution Up to 600 x 600 dpi
Print Memory 1 GB (RAM)
Printer Language UFR II, PCL6, PCL5, Adobe® PostScript 3®
Network Security Authentication Standard: Department ID Authentication. Network Standard: TLS1.3, IPSec support, IEEE 802.1X authentication, SNMPv3, IP Address Filtering, Configure ON/OFF settings for network application functions, Job Log Conceal Function, Restricted access to the printer's storage media, Verify System at Startup
Connectivity USB 2.0 High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g/n
Operating Systems Windows®10 / Windows®11 / Windows®Server2012 / Windows®Server2012 R2 / Windows®Server2016 / Windows®Server2019 / Windows®Server2022 macOS 10.13 (or later)
Paper Capacity Standard: 250-Sheet Standard Cassette, 100-Sheet Stack Bypass (Multipurpose Tray), Optional: 550-Sheet Paper Cassette (AH-1)
Min / Max Paper Size Standard / Optional Cassette: 4.1 x 5.8 to 8.5 x 14 Inches / Multipurpose Tray: 3 x 5 Inches to 8.5 x 14 Inches
USB Direct Print JPG, TIFF, PDF
Display Panel 5 Inch, Color Touch LCD
Print Volumes 750-4,000 RMPV (Recommended Monthly Print Volume)
Energy Consumption Approx: 1250 W (Max., w/o Accessories), 8 W (Standby), 0.1 W (Sleep Mode)
ENERGY STAR Yes
EPEAT Silver
Box Dimensions 21.25" (W) x 22" (D) x 20.5" (H)
Box Weight 47.25 lbs.
Unit Dimensions 16.6" (W) x 18.1" (D) x 14.8" (H)
Unit Weight 34.4 lbs.
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
