Canon Support for EOS Rebel T1i | Canon U.S.A., Inc.
EOS Rebel T1i
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 03.26.09
File Size 1.89 MB
Date 10.15.10
File Size 8.08 MB
Date 07.23.12
File Size 6.38 MB
Date 01.25.12
File Size 10.69 MB
Date 10.26.10
File Size 16.56 MB
Date 10.15.10
File Size 8.41 MB
Date 04.13.09
File Size 6.06 MB
Date 07.23.12
File Size 6.88 MB
Date 10.21.10
File Size 11.20 MB
Date 03.05.10
File Size 12.70 MB
Date 03.26.09
File Size 1.49 MB
Date 10.02.24
File Size 142.00 B
Date 09.30.24
File Size 142.00 B
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels
Effective pixels: Approx. 15.10 megapixels
Total Pixels
Total pixels: Approx. 15.50 megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1) Self Cleaning Sensor Unit
(2) Dust Delete Data appended to the captured image
(3) Manual cleaning of sensor
Recording Format
Design rule for Camera File System 2.0 and Exif 2.21
Image Format
Still: JPEG, RAW (14-bit, Canon original), RAW+JPEG
Video: MOV (Image data: H.264, Audio: Linear PCM)
File Size
(1) Large/Fine: Approx. 5.0MB (4752 x 3168 pixels)
(2) Large/Normal: Approx. 2.5MB (4752 x 3168 pixels)
(3) Medium/Fine: Approx. 3.0MB (3456 x 2304 pixels)
(4) Medium/Normal: Approx. 1.6MB (3456 x 2304 pixels)
(5) Small/Fine: Approx. 1.7MB (2352 x 1568 pixels)
(6) Small/Normal: Approx. 0.9MB (2352 x 1568 pixels)
(7) RAW: Approx. 20.2MB (4752 x 3168 pixels)
Exact file sizes depend on the subject, ISO speed, Picture Style, etc.
File Numbering
Consecutive numbering, auto reset, manual reset
RAW + JPEG Simultaneous Recording
Provided (RAW, RAW+JPEG)
Color Space
sRGB, Adobe RGB selectable
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
Settings
Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom
Color Temperature Compensation
White balance correction: &plusmn;9 stops in full-stop increments
White balance bracketing: &plusmn;3 stops in full-stop increments
Blue/amber direction or magenta/green direction possible
Color Temperature Information Transmission
Provided
Type
Eye-level pentamirror
Coverage
Vertical/Horizontal approx. 95%
Magnification
Approx. 0.87x (-1m-1 with 50mm lens at infinity)
Eye Point
Approx. 19mm (from eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0m-1 (diopter)
Focusing Screen
Fixed, Precision Matte
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60, no mirror cut-off with EF600mm f/4L IS USM or shorter lenses)
Viewfinder Information
AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture, AE lock, exposure level, ISO speed, exposure warning), flash information (flash ready, high-speed sync, FE lock, flash exposure compensation), monochrome shooting, white balance correction, maximum burst, SD memory card information
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL-CT-SIR AF-dedicated CMOS sensor
AF Points
9 AF points (center AF point is cross-type)
AF Working Range
EV -0.5-18 (at 73&deg;F/23&deg;C, ISO 100)
Focusing Modes
Auto, One-Shot AF, Predictive AI Servo AF, AI Focus AF, Manual Focusing (MF)
AF Point Selection
Automatic selection, manual selection
Selected AF Point Display
Superimposed in viewfinder and indicated on LCD monitor
AF Assist Beam
Intermittent firing of built-in flash
Effective range: Approx. 4.0m/13.1 ft. at center, approx. 3.5m/11.5 ft. at periphery. When EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
Metering Modes
35-zone TTL full-aperture metering Evaluative metering (linkable to any AF point)Partial metering (approx. 9% of viewfinder at center)Spot metering (approx. 4% of viewfinder at center)Center-weighted average metering
Metering Range
EV 1-20 (at 73&deg;F/23&deg;C with EF50mm f/1.4 USM lens, ISO 100)
ISO Speed Range
ISO 100-3200 (in 1-stop increments), H1: 6400 H2: 12800; Basic Zone modes: ISO 100-3200 set automatically
Exposure Compensation
Manual: &plusmn;2 stops in 1/3- or 1/2-stop increments (can be combined with AEB)
AE Lock
Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved; Manual: By AE lock button
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/4000 sec. to 1/60 sec., X-sync at 1/200 sec.
1/4000 sec. to 30 sec., bulb (Total shutter speed range.
Available range varies by shooting mode)Soft-touch electromagnetic release10-sec. or 2-sec. delay or 10-sec. delay plus continuous shootingRemote Switch RS-60E3
Remote Controller RC-1/RC-5
Type
Shutter Speeds
Shutter Release
Self Timer
Remote Control
Type
Retractable, auto pop-up flash
Guide Number
13/43 (ISO 100, in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights in viewfinder
Flash Coverage
17mm lens angle of view
FE Lock
Provided
Flash Exposure Compensation
Drive Modes
Single, continuous, self-timer (10 sec. or 2 sec. delay)/remote control
Continuous Shooting Speed
Max. 3.4 shots/sec. (with One-Shot AF or AI Servo AF)
Maximum Burst
JPEG (Large/Fine): Approx. 170, RAW: Approx. 9
Based on Canon's testing standards with a 2GB SD memory card, ISO 100 and Standard Picture Style
Varies depending on the subject, SD memory card brand, image-recording quality, etc.
Shooting Modes
Still photo shooting and video shooting
Focusing
Autofocus (One-Shot AF): Live mode, Face Detection Live mode, Quick mode; Manual focus (5x or 10x manually)
Metering Modes
Real-time evaluative metering with image sensor
Metering Range
EV 0-20 (at 73&deg;F/23&deg;C with EF 50mm f/1.4 USM lens, ISO 100)
Grid Display
Provided (Two grid displays)
Exposure Simulation
Provided
Silent Shooting
Not provided
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0 in.
Pixels
Approx. 920,000 dots (VGA)
Coverage
Approx. 100%
Viewing angle: 170&deg;
Brightness Control
7 levels provided
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
Single image, Single image + Image-recording quality, shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image, image jump (by 1/10/100 images or shooting date)
Highlight Alert
Provided (Overexposed highlights blink)
Protection
Erase protect (or cancel) each image individually
Erase
Single image, selected images or all images in the SD card can be erased (except protected images)
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW images captured with the EOS Rebel T1i
Easy Print feature
Provided
DPOF
Version 1.1 compatible
Compatible Images
JPEG and RAW images
*Only JPEG images can be transferred as wallpaper on the personal computer screen
Custom Functions
Total 13
My Menu Registration
Up to 6 menus, Custom functions and other top-tier options can be registered
Battery
One Battery Pack LP-E5
AC power can be supplied via AC Adapter Kit ACK-E5
With Battery Grip BG-E5, AA-size batteries can be used
Number of Shots
Battery Life
The above figures apply with a fully-charged Battery Pack LP-E5
The figures above are based on CIPA (Camera & Imaging Products Association) testing standards
Battery Check
Automatic
Power Saving
Provided. Power turns off after 30 sec., 1, 2, 4, 8, 15 min.
Back-up Battery
Built-in secondary battery
Start-up Time
Approx. 0.1 sec. (based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 5.1 x 3.8 x 2.4 in./128.8 x 97.5 x 61.9mm
Weight
Approx. 16.9oz./480g (body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: EOS Rebel T1i: Firmware Version 1.1.2
Advisory Type
Date 11.27.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
