Date 01.04.08
File Size 3.66 MB
Software Development Kit
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at https://www.usa.canon.com/support/sdk. To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
Type and Major Components
Type 35mm focal plane shutter SLR (Single-Lens Reflex) autofocus/ autoexposure camera with built-in motor drive and retractable flash
Compatible Lenses Canon EF lenses (Except EF-S)
Lens Mount Canon EF mount(electronic signal transfer system)
Viewfinder
Type SLR-type, eye level proof prism mirror
Picture Coverage 90% vertical and horizontal coverage of actual picture area
Magnification 0.70x magnification with 50mm lens at infinity
Dioptric Adjustment Adjusted to -1. (18.5 mm eye relief)
Focusing Screen Fixed, full surface new laser-matte screen marked with focusing points.
Mirror Quick-return half mirror.
Viewfinder Information Shutter speed ( if unsuitable, blinks at 2Hz as a warning), Aperture (if unsuitable, blinks at 2Hz as a warning), AE lock or FE lock indicator(partial metering at center), Exposure level scale with dot indicators in 1/2 stop increments (+/- 2stops), Flash ready light (blinks at 2 Hz if flash range is ineffective during Fe lock), High-speed sync indicator (FP flash), In-focus indicator (Blinks at 2 Hz if focus cannot be achieved), AF point selection, Active AF point.
Autofocus
Type TTL-SIR (Secondary Image Registration) CMOS Sensor.
Focusing Point Selection The focusing point can be selected by camera (automatic) or by user (manual).
Focus Modes 1. Autofocus: One of the following three AF modes is set automatically depending on the picture-taking mode. The shutter does not release until focus is achieved.
a. One-Shot AF: Autofocus locks when focusing is achieved.
b. Predictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts.
C. Al Focus AF for automatic switching between One-Shot AF and predictive AF for moving subjects.
2. Manual Focus: Setting the lens' focus mode switch to MF enables manual focusing with the focusing ring.
Focus Operation Autofocus is activated by pressing the shutter button halfway.
AF Working Range EV 1-18 (at ISO 100)
AF Assist Method Beam automatically emitted when necessary and aimed at the area covered by the active focus point.
Exposure Control
Metering Modes 1. TTL full-aperture metering using 35-zone SPC (Silicon Photocell). Three metering patterns available.
a. 35-zone evaluative metering
b. central partial metering which covers approximately 9.5% of finder area.
c. Center-weighted average metering (Set automatically in M mode.)
2. E-TTL; 7 point, 35 zone pre-flash metering using Speedlite 550EX, 420EX, or 220EX.
3. A-TTL, TTL Flash Metering: off-the-film, 3 zone A-TTL autoflash linked to focusing point, 3 zone TTL autoflash metering.
Metering Range EV 1-20(with 50mm f/1.4 lens at ISO 100)
Exposure Modes 1. Intelligent program AE with variable shift.
2. Shutter speed-priority AE
3. Aperture-priority AE
4. Auto DEP
5. Full Auto (Intelligent program AE, unshiftable.
6. Programed Image Control Modes: Portrait,Landscape, Close-up, Sports, Night Portrait and Flash Off
7. E-TTL program flash AE
8. A-TTL program flash AE
9. TTL program flash AE
10. Metered Manual
Multiple Exposure Up to 9 exposures can be preset. Automatically clears upon completion. Cancellable midway.
Exposure Compensation 1. Auto Exposure Bracketing(AEB) up to +/- 2 EV in 1/2 steps.
2. Manual exposure compensation up to +/- 2 EV in 1/2 steps.
3. Unavailable in the Full Auto and Programmed modes.
Shutter
Type Vertical-travel, focal plane shutter with all speeds electronically controlled. Front and rear shutter curtains both have dedicated electromagnetic release control. (Curtain speed: 6.3ms / 24mm)
Shutter Speeds 30 to 1/2000 sec., Bulb; X-sync at 1/90 sec. Can be set in 1/2-stop increments.
Built-in-Flash
Type Built-in, retractable TTL autoflash head in the pentaprism. Auto pop-up and serial-controlled.
Guide Number 39 ft. / 12m (ISO 100)
Flash Coverage Angle Covers the angle of view of 28mm lens.
Flash Duration 1ms or less
Recycling Time Approximately 2 seconds. The icon lights in viewfinder when ready.
Color Temperature Equivalent to daylight.
Shooting Distance Range
Red-Eye Reduction Red-Eye Reduction lamp lights while the shutter button is pressed halfway and focusing and metering are achieved.
Film Transport
Film Loading Automatic prewind system. After film positioning and back over closure, the film automatically winds to the 1st frame.
Film Speed Setting ISO 25-5000 automatically set in 1/3 step increments according to DX code. Can also be set manually from ISO 6-6400 in 1/3 step increments.
Film Transport Single-frame advance or continuous advance set automatically according to the picture-taking mode.
Quiet Film Transport: Film winding sound level approx. 60 dB
Film Transport Confirmation: By up/down counting of frame counter in LCD panel.
Film Wind One of two modes can be set: Single Frame and Continuous. (In Continuous Mode, with AF locked, approx, 1.5 fps.)
Film Rewind Automatically rewinds at the end of roll. Midroll rewinding possible.
Shooting
Shooting Modes Full Auto, Portrait, Landscape,Close-up Sports, Night Scene, Flash Off, Intelligent Program AE, Shutter Speed-Priority Are, Aperture-Priority AE, Manual Exposure, Automatic Depth -of-Field AE.
Continuous Shooting Approx 1.5 images/sec
Power Source
Battery TWO CR2 lithium batteries housed inside the camera grip.
Battery Check Battery level is displayed by the battery level indicator on the LCD panel. Batter level is indicated in one of four levels.
Shooting Capacity
Dimensions
Size (W x H x D) 5.1 x 3.5 x 2.5 in. / 130 x 88 x 64mm
Weight 12.9 oz. / 365g without batteries
Other
Date/Time Imprint (EOS Rebel K2 Date only) Day/Month/Year, Month/Day/Year, Year/Month/Date, Date/Hour/Minute
All Data are based on Canon's Standard Test Method. Subject to change without notice.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
