Canon Support for EOS-1D Mark III | Canon U.S.A., Inc.
EOS-1D Mark III
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
Wireless Setup
- Available Communication Functions on the EOS-1D X Mark III
- Basic Communication Settings on the EOS-1D X Mark III
- Camera Connect Communication from Smartphones
Using Wi-Fi
Using the WFT-E9
SELECT ERROR CODE
Type | High-sensitivity, high-resolution, single-plate, CMOS sensor |
Pixels | Approx. 10.10 megapixels |
Total Pixels | Approx. 10.70 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the CMOS sensor |
Dust Deletion Feature | (1) Automatic sensor cleaning (2) User-activated sensor cleaning (3) Dust Delete Data appended to the captured image |
Recording Format | DCF 2.0 (Exif 2.21): JPEG, RAW and RAW+JPEG simultaneous recording possible. Multiple options for recording images on two memory cards, and onto compatible external USB hard drives (via optional Wireless File Transmitter WFT-E2A) |
Image Format | JPEG, RAW (Canon .CR2) |
File Name | Preset code, User setting1 (4 characters), User setting2 (3 characters + 1 image size character) |
File Size | (1) JPEG/Large: Approx. 3.5MB (3,888 x 2,592) (2) JPEG/Medium 1: Approx. 2.8MB (3,456 x 2,304) (3) JPEG/Medium 2: Approx. 2.1MB (2,816 x 1,880) (4) JPEG/Small: Approx. 1.2MB (1,936 x 1,288) (5) RAW: Approx. 13.0MB (3,888 x 2,592) (6) sRAW: Approx. 7.6MB (1,936 x 1,288) |
Folders | Folder creation/selection enabled |
Recording Functions | (1) Standard (2) Auto switch media (recording media switched automatically) (3)Rec. separately (specified image size for each recording media) (4) Rec. to multiple (same image recorded to all recording media) |
Backup Recording | With WFT-E2/E2A attached, all images and folders in the CF card and SD card can be backed up to USB external media |
File Numbering | (1) Continuous numbering (2) Auto reset (3) Manual reset (the image numbering is reset to 0001, a new folder is created automatically) |
Image Copy | Image copying between recording media enabled (images with checkmarks or all images in folder or card) |
Color Space | sRGB, Adobe RGB |
Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3 |
Settings | Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, five Custom WB settings (1-5), user-set Color Temperature (2,500,10,000K), five Personal White Balance PC-1 to PC-5 (Total 10 WB types) |
Auto White Balance | Auto white balance, taken from imaging sensor |
Color Temperature Compensation | White balance bracketing: Three consecutive images, Up to +/- 3 levels in 1-stop increments White balance correction: blue/amber bias and/or magenta/green bias +/- 9 levels; manually set by user When blue/amber bias and magenta/green bias set with White balance correction, white balance bracketing cannot be set together during white balance correction |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR with fixed pentaprism |
Coverage | Approx. 100% horizontally and vertically |
Magnification | 0.76x (-1 dpt with 50mm lens at infinity) |
Eye Point | Approx. 20mm |
Dioptric Adjustment Correction | -3.0 to +1.0 diopter |
Mirror | Quick-return half mirror (Transmission: reflection ratio of 37:63) |
Viewfinder Information | AF (AF points, focus confirmation light), Exposure (metering mode, spot metering area, shutter speed, aperture, manual exposure, AE lock, ISO speed, exposure level, exposure compensation, exposure warning), Flash (flash ready, high-speed sync, FE lock, flash exposure level), Image (JPEG recording, RAW recording, shots remaining, white balance correction, memory card information), Battery check |
Depth Of Field Preview | Enabled with depth-of-field preview button; possible in Live View mode |
Eyepiece Shutter | Built-in |
Type | TTL-AREA-SIR AF-dedicated CMOS sensor |
AF Points | 19 cross-type AF points (plus 26 Assist AF points) |
AF Working Range | EV -1 ,18 (ISO 100 at 73°F/23°C) |
Focusing Modes | Autofocus (One-Shot AF, Predictive AI Servo AF), Manual Focus (MF) |
AF Point Selection | Automatic selection; Manual AF point selection: 19 AF points, Inner 9 AF points (C.Fn III-9-1), Outer 9 AF points (C.Fn III-9-2) |
Selected AF Point Display | Superimposed in viewfinder and on LCD panel |
AF Assist Beam | None. Emitted by EX-series Speedlite or optional ST-E2 Speedlite Transmitter |
Metering Modes | 63-zone TTL full aperture metering (1) Evaluative metering (linked to all AF points) (2) Partial metering (approx. 13.5% of screen, at center) (3) Spot metering (approx. 3.8% of screen)Center spot metering AF point-linked spot metering Multi-spot metering (max. 8 spot metering entries)(4) Center weighted average metering |
Metering Range | EV 0-20 (ISO 100 at 73°F/23°C with EF 50mm f/1.4 USM lens, ISO 100) |
ISO Speed Range | Equivalent to ISO 100-3200 (in 1/3-stop or whole stop increments), ISO speed can be expanded to ISO 50 and 6400 (via C.Fn I-3)**Standard Output Sensitivity. Recommended Exposure Index. |
Exposure Compensation | Exposure Compensation (user-set): +/-3 stops in 1/3- or 1/2-stop increments. Auto Bracketing (AEB): 3 shots, up to +/- 3 stops, in 1/3 or 1/2 stop increments, in all exposure modes. Can be changed via C.Fn I-6 to 2, 5, or 7 shots. Bracketing order can be changed via C.Fn I-5. |
AE Lock | Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved Manual (user-set): By AE lock button in all metering modes |
Shutter | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/8000 to 30 sec. (1/3-stop increments), X-sync at 1/300 sec. (with EOS Speedlites; 1/250 maximum with other shoe-mount flashes, and up to 1/60th or faster with studio strobes)Soft-touch electromagnetic release10 sec. delay, 2 sec. delayCanon N3 type terminal |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled |
Shutter Speeds | 1/8000 to 30 sec. (1/3-stop increments), X-sync at 1/300 sec. (with EOS Speedlites; 1/250 maximum with other shoe-mount flashes, and up to 1/60th or faster with studio strobes) |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10 sec. delay, 2 sec. delay |
Remote Control | Canon N3 type terminal |
EOS Dedicated Speedlite | E-TTL II autoflash with all EX Series Speedlites |
Zooming to Match Focal Length | Provided |
Flash Metering | E-TTL II autoflash |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | Flash function settings, Flash C.Fn settings |
PC Terminal | Provided; accepts third-party flash units with sync line voltages up to 250V maximum |
Drive Modes | Single, silent, high-speed continuous (approx. 10 fps), low-speed continuous (approx. 3 fps), 10- or 2-sec. self-timer |
Continuous Shooting Speed | Approx. 10 fps (at a shutter speed of 1/500 sec. or faster in all recording modes); fastest speed can be lowered if desired via Custom Function III-16 |
Maximum Burst | JPEG: approx. 110 frames (Large/Fine, at standard level 8 compression setting) RAW: approx. 30 frames RAW+JPEG: approx. 22 frames (Large/Fine) |
Shooting Modes | (1) Remote Live View shooting (with a personal computer installed with EOS Utility) (2) Live View shooting |
Focusing | Manual focus |
Metering Modes | Evaluative metering with the image sensor |
Metering Range | EV 0-20 (at 23°C/73°F with EF 50mm f/1.4 USM lens, ISO 100) |
Magnified View | Magnifiable by 5x or 10x at AF point |
Grid Display | Provided |
Exposure Simulation | Provided |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0 in. |
Pixels | Approx. 230,000 pixels |
Coverage | Approx. 100% |
Brightness Control | 7 levels provided |
Display Format | Single image, 4-image index, 9-image index, Jump, Magnified zoom (approx. 1.5x to 10x), Histogram, Auto rotate, Rotate Live view: view image before shooting on LCD monitor; live histogram and live simulation of exposure level possible with C.Fn IV-16-1 |
Highlight Alert | In the single image display and (INFO) display, over-exposed highlight areas will blink |
Protection | Single image, all images in a folder, or all images in the memory card can be protected or cancel the image protection |
Erase | Single image, all images in a folder, all images in the memory card or check-marked images can be erased or unprotected |
Compatible Printers | PictBridge-compatible printers |
Printable Images | JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW/sRAW images captured with the EOS-1D Mark III |
DPOF | Version 1.1 compatible |
Compatible Images | JPEG and RAW/sRAW images *Only JPEG images can be transferred as wallpaper on the personal computer screen |
Custom Functions | Total 57 |
My Menu Registration | Provided |
Save Camera Settings | Provided |
Register Basic Camera Settings | Provided |
C.Fn Registration Settings | Provided |
Recording Methods | The sound clip recorded with the built-in microphone is attached to the image |
File Format | WAV |
Recording Time | Max. 30 sec. per sound clip |
Menu Categories | (1) Shooting (2) Playback (3) Setup, (4) Custom function/My Menu |
LCD Monitor Language | 18 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Simplified/Traditional Chinese, Korean, Japanese) |
Battery | One dedicated lithium-ion battery LP-E4 AC power can be supplied via the AC Adapter Kit ACK-E4 |
Battery Life | At 73°F/23°C: Approx. 2200 At 32°F/0°C: Approx. 1700 The above figures apply when a fully-charged Battery Pack LP-E4 is used |
Battery Check | Automatic |
Power Saving | Provided. Power turns off after 1, 2, 4, 8, 15, 30 min. |
Date/Time Battery | One CR2025 lithium battery |
Start-up Time | Approx. 0.2 sec. |
Dimensions (W x H x D) | 6.1 x 6.2 x 3.1 in./156 x 156.6 x 79.9mm |
Weight | 40.7 oz./1,155g |
Working Temperature Range | 32-113°F/0-45°C |
Working Humidity Range | 85% or less |
Type | For LP-E4 Rechargeable lithium ion battery |
Rated Voltage | 11.1 V DC |
Battery Capacity | 2300mHh |
Dimensions (W x H x D) | 68.4 x 34.2 x 92.8mm/2.7 x 1.3 x 3.7 in. |
Weight | 180g/6.3 oz. (excluding protective cover) |
Type | For LC-E4 Charger dedicated to the Battery Pack LP-E4 |
Recharging Time | Approx. 120 min. (for 1 pack) |
Rated Input | 100-240 V AC (50/60 Hz) 12 V/24 V DC |
Rated Output | 12.6 V DC, 1.55 A |
Working Temperature Range | 0°C-40°C/32°F - 104°F |
Dimensions (W x H x D) | 155 x 52.3 x 95mm/6.1 x 2.1 x 3.7 in. |
Weight | 340g/12.0 oz. (excluding power cord and protective covers) |
Type | For ACK-E4 |
Rated Input | 12.6 V DC |
Rated Output | 11.1 V DC |
Cord Length | Approx. 2.3 m/7.5 ft. |
Working Temperature | 0°C-45°C/32°F-113°F |
Working Humidity | 85% or less |
Weight (Approx.) | 165g/5.8 oz. (excluding protective cover) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
