Canon Support for CanoScan 5000F | Canon U.S.A., Inc.
CanoScan 5000F
Filter & Sort
Download Type
<p><b>Find Software &amp; Drivers</b></p> <p>Software &amp; drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Results will appear after selecting an Operating System and Version above
Date 04.01.07
File Size 2.09 MB
Date 04.01.07
File Size 2.70 MB
Date 12.27.11
File Size 2.57 MB
Scanner Type Flatbed, color and monochrome
Scanning Element Charge-Coupled Device (CCD)
Light Source Cold Cathode Fluorescent Lamp
Scanning Mode 48-bit internal/external, Grayscale - 16-bit internal/8-bit external, Black & White, Text Enhanced
Max. Document Size 8.5" x 11.7"; Film - 35mm x 3 frames (negatives), 35mm x 2 frames (mounted slides)
Interface USB 2.0 Hi-Speed
Dimensions (W x D x H) 10.9" x 20.0" x 4.2"
Weight 7.5 lbs.
OS Compatibility Windows&reg; 98/2000/Me/XP, Mac&reg; OS 9.0 - 9.x, Mac OS X v10.1 or later (Classic mode), Mac OS X v10.1.3 (Native mode)
Software CanoScan Setup CD-ROM****** Including: ScanGear&reg; CS (Windows/Mac), CanoScan Toolbox (Windows/Mac), ArcSoft&reg; PhotoStudio&reg; (Windows/Mac), ArcSoft PhotoBase&#153; (Windows/Mac), ScanSoft&reg; OmniPage&reg; SE OCR&#153; (Windows/Mac OS 9.1 to 9.x, Mac OS X Classic mode), NewSoft&reg; Presto! PageManager&reg; (Windows only) and NewSoft Presto! BizCard&reg; (30-day trial version, Windows only)
Power Source 120V AC, 60 Hz
Max. Power Consumption 14.8 W (5.6 W standby)
Operating Temperature: 50&deg; - 95&deg;
Operating Humidity: 20% - 80% RH
Warranty 1-year limited warranty with InstantExchange warranty program (conditions and restrictions apply, see www.canontechsupport.com for details)
&#134; Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
* Based on Canon Inc. testing, using Pentium 4, 1.7 GHz, 256MB RAM, using Adaptec DUO CONNECT. Scanning an approx. 8.5" x 11" image at 600 dpi. Results may vary.
** Windows users only.
*** Available only when using 2400 or less dpi.
**** Systems with Pentium&reg; III or higher, Celeron&reg; (566MHz or higher), AMD: Athlon&#153;, Athlon MP, Athlon XP or Duron are recommended for optimal performance.
***** ScanGear CS driver (Plug-in compatible) and CanoScan Toolbox, quick scanning utility are available in Mac OS X native mode.
****** System requirements vary by application.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
